Front Speaker Replacement - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 03-13-2010, 11:52 AM Thread Starter
I read on another forum that if the front speakers on my 2006 Cobalt LT are replaced with aftermarket speakers that new screw holes need to be drilled out to accommodate them even if they're the correct 6 3/4 size. It even went so far as to say that I would need to waterproof around the bracket to keep rain water out Is this true or will any speaker of the correct size fit properly?
strangelove262 is offline
post #2 of 6 (permalink) Old 03-13-2010, 12:04 PM
The correct speaker size is 6 1/2
Check this out > http://www.yourcobalt.com/forums/ins...light=speakers
---------- Post added at 02:04 PM ---------- Previous post was at 02:04 PM ----------
Welcome to the forum BTW!
post #3 of 6 (permalink) Old 03-13-2010, 12:58 PM
blazerlow's Avatar
YC to the rescue
blazerlow is offline
post #4 of 6 (permalink) Old 03-13-2010, 04:37 PM
finnscobalt's Avatar
I had mine replaced by a local shop and they install 6 1/2's, made a new mount for them and no waterproofing. As long as all your door seals are good, no need to waterproof.
sig pic courtesy of GBALT05
finnscobalt is offline
post #5 of 6 (permalink) Old 08-29-2010, 11:42 PM
That is completely correct. i had the same problem.
shane_t is offline
post #6 of 6 (permalink) Old 11-06-2010, 09:52 PM
guys simple solution found this out after ordering a bracket and not being able to get the door panel back flat, take the stock speaker and cut the speaker off the mount then break off the top ring from stock stuff screw ur new speaker in and its perfect
throwinsparksat is offline
