| Audio/Video Talk about Audio/Video and other mobile electronics here |
so they supplied solenoids for the locks then??
![]() -SSC Springs - TTR Rear sway bar - ADR 17" Battle Exe rims wrapped in Toyo Proxes 4 - Little Intake work w/ K&N high flow & Airbox mod - - 8" 200 Watt Bazooka Tube - Blaupunkt Head unit - Blaupunkt speakers - Lights/neon inside - Streetglow Optx underbody - ![]() NJ Tuners CarDomain Cobalt Facebook album "Let it be." |
Best alarm you can get are these. Viper - Vehicle Security | Remote Start | GPS Tracking Check your local shops to see who carries them, the best of the best. But when installing an alarm, the alarm is only as good as the install, make sure you get it done at a realiable shop. bad alarm means lots of problems. The vip alarm with keyless entry, remote start, alarm, and 2 way pager only costed 100$ for install at every place i checked out. (100 for the install 400 for the system)
2007 Black LT coupe 35% Tint all around - Completly debadged - Side Moldings Removed KICKER ZX 650 RMS interior amp - KICKER ZX1000 RMS Sub Amp 1 KICKER 12" L7 - All new pioneer interiors - Pioneer Avic Z2 W/ GPS Rockford 1 Farad capcitor - Trunk, Doors, and Rear deck Dynamated - PS2 with guitar hero Blue footwell neons - Two Alpine type S Tweeters More to come, just waiting on parts:D my trunks gonna be crazy |
Amazon.com: Viper 1002 Car Alarm Security System: Electronics
How does that look to you?? I just want something that makes some noise in the event that something happens. Snake890217 added 4 Minutes and 11 Seconds later... or this... http://cgi.ebay.com/NEW-DEI-VIPER-PYTHON-HORNET-740T-CAR-ALARM_W0QQitemZ380053694856QQcmdZViewItem?hash=ite m380053694856&_trkparms=72%3A1075%7C39%3A1%7C66%3A 2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
The Viper alarm systems are really nice, I have one installed on my car with remote start. Did cost some money and time, but only because they needed the bypass to get the remote start to work. The reason why I got mine was the fact that when my car was broken into the alarm didn't go off (criminal shattered my window), I went to the dealer to ask why it didn't go off and apparently they only go off when the car is being forced to open, so I wanted the upgrade to eliminate that potential problem.
So if my father is VERY electronically inclined is this job more... possible... don't know the word I'm looking for lol? He's been working in electronics, making circuit boards and such, even some for the military, for 30+ years. Also did lots of stuff with vehicles in the Army but that was in the 60s, mostly mechanics though.
![]() -SSC Springs - TTR Rear sway bar - ADR 17" Battle Exe rims wrapped in Toyo Proxes 4 - Little Intake work w/ K&N high flow & Airbox mod - - 8" 200 Watt Bazooka Tube - Blaupunkt Head unit - Blaupunkt speakers - Lights/neon inside - Streetglow Optx underbody - ![]() NJ Tuners CarDomain Cobalt Facebook album "Let it be." Last edited by Snake890217; 08-23-2008 at 05:06 PM. |
Here is a diagram for you
12volts (+) red/blk 50amp BCM/c3/pin D1 Ignition 1 (+) yellow ign. harness/ or bcm/c4/ pin D3 Power lock and unlock (-) white - driver kick or bcm/c1/ pin 7 lock is straight - trigger, unlock - trigger thru 1500ohm resistor must use relays parking lights (-) brown/white switch or bcm/c2/ pin 5 trunk release (-) tan switch or bcm/c2/ pin 10 trunk pin switch (-) orange/black pin switch or bcm/c1/ pin 55 left and right door bcm/ c1 triggers (-) LF door gray/black pin 22 RF door tan/white pin 19 LR door blue/black pin 1 RR door green/blk pin 20 must diode isolate each wire seperately this should be enough for an alarm, i suggest you have a pro do it. I have been doing this for years. I was also a mechanic for 5 years, they still don't know crap about electronics. Electricians are meant to wire houses. I have seen alot of junk work out there. Be careful with who you have install your stuff. I run a Viper 560 alarm remote start on my cobalt. All of them: python, viper, valet, rattler, etc.... are made by D.E.I... Directed Electronics. Great stuff, worthless techs.
2008 Cobalt LS Pioneer D3, Alpine Type-X Ref 6.5's up front, Alpine Type-S 10" takin care of the rear. 35% tint on every window, O.Z. Ultraleggara 17", added power windows and locks. Keepin it clean. |
