| Audio/Video Talk about Audio/Video and other mobile electronics here |
ah yessss the mysterious blue electronic smoke generally followed by the smell of ozone.
![]() -SSC Springs - TTR Rear sway bar - ADR 17" Battle Exe rims wrapped in Toyo Proxes 4 - Little Intake work w/ K&N high flow & Airbox mod - - 8" 200 Watt Bazooka Tube - Blaupunkt Head unit - Blaupunkt speakers - Lights/neon inside - Streetglow Optx underbody - ![]() NJ Tuners CarDomain Cobalt Facebook album "Let it be." |
and then the typical "why is it not working?"
Vizzo, no offense, but 143 is kinda low for what you're running. Is the box built to spec? And what kind of port setup are you using? Just curious....
SQ is OK. Built the box in a day so I didn't miss SBN. My voltage drops pretty bad so I need a better battery when I build my new box. I plan to mess with this box a little more. These subs actually are louder in small ported enclosures. I plan to add another 6" aeroport and resin the inside. I'm also going to replace the blankets with trim panels
. These SPAIRs are pretty well worn out (notice the duct tape surround) so I'm sure new SPAIRs will help out a decent amount.
143 isn't too bad for no tuning or testing. Box is built slightly larger than several other competitors told me the Solo Xs would perform well in. My port is a 6" Aeroport as of now. Still have a lot of testing to do. I had a Grand Am before this with 2 10" L7s, same amp, and that could consistantly do 145. I even pulled a 143 @ 38hz with a pair of 10" Alpine Type Rs. Spent several months on that car and box so I know I have a lot of work to do, but I love it and know that it won't be too long before I am close to 150 on my Termlab. :D
Eclipse CD5000 Head Unit
Kicker 6 1/2's in the front Kicker 6 x 9's in the back MTX 4-channel Memphis prd1000.1 2 12" Kicker L7's in seperate ported boxes I don't have any numbers but I can sure shake some walls when I pass by
![]() The cobalt is getting a new rockford fosgate amp, to push the 2-10" in it. havent decided what size, may look @ the factory pioneer first, if i can find it
