yeah, i agree with blackbalt, i would change the second O2 sensor, and clear the codes. Basic knowledge would be to replace both sensors while the car is in the air.
Another update
Well, I took the dp off and put the stock one back on cleared the code but the light still came on. I took it the dealer today and they said the o2 sensor is bad, I told them I just put it in, and they said that it is probably because it is not a gm one. The gm sensor is over 3 times as much as the Bosch one I bought. In all it was $382 for the diagnoses, part and install. They said the problem should be solved so we will see.
06 majestic amethyst metallic (purple) LT coupe Injen CAI Pacesetter catback with Magnaflow muffler |
Please Help!
I had the same problem. I agree with the other posts as you need to check and see if the cigarette lighter plug under the radio works. If not, it is the fuse. The fuse is a 15 amp fuse labeled cigar located in the fuse panel under the hood.
my 2 cents...
Can I add my 2 cents.... No problem with my Balt but have a 99 Ford windstar, check engine light on, Autozone scanned, said it was a dirty MAF or o2 sensors. Replaced MAF and still engine light, took it to Ford, after $95 diagnostic told it was the pcv valve. replaced it, same problem. Looking on Craigslist, found a Master Tech that use to work with Ford, Came over (house call) said it was a gasket ( can't remember which one). He came over Sat at 9:30 am, picked up van and dropped it off at 1:30pm. Gasket replaced, new plugs etc.. all for $270 parts and labor. Light is out!
Moral of story, don't always believe what autozone tells you is wrong when your car throws a CEL, take what they give you and research it...unless you like replacing parts. |
