Reset Your Keyfob, No Dealer Needed..... - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
Electrical Electrical DIY/How-to's
post #1 of 11 (permalink) Old 09-26-2010, 08:59 AM Thread Starter
The fix is at the end if you don't care about how I found it.
So, I have read the stories... "This is a dealer only fix...", "No Owner Fix Possible....", Etc.
When I got my cobalt the keyfob didn't work, the battery had died at one point and it was no longer associated with the car.
I did a butt load of research and found that there was no way to reset it like on my other chevy cars. I called the dealer and was told in fact there was no way to fix this other than going there and paying 50-60 bucks to have them reprogram it.
My car got rear ended a week later and all of the sudden the keyfob just started working.
So I suggest you just go get rear ended.............
Although this fixed my car I do not recommend you try this....
My GF drives a cobalt (hers is an 05 mine is an 06), her KF battery died recently and we couldn't get it working again.......
I hate dealer only fixes and was determined to find another option. I shouldn't have to pay them 50 bucks for 15 seconds....
So I searched and searched and searched, and eventually I found a post saying that pulling the fuse for the radio would reset the system.... No way, that's just to damn easy....
So I tried it, and it worked.. Here is what I did.
The Fix.
I pulled the interior fuse cover from the passenger seat.
I located and pulled the 10A fuse for the Radio (labeled RDO).
I turned the car to the on position to verify the radio was disabled.
I turned the car back off and removed the keys.
I waited 30 seconds (I'm a Network Engineer, we always wait thirty seconds after unplugging something).
I put the fuse back into the correct spot.
I then held down the lock and unlock key on the keyfob at the same time till the locks on the doors activated.
I then tested the keyfob and made sure it was locking and unlocking the doors and activating the security system.
This process did reset my security settings on her car so I had to go through the reset process (holding in the information and reset key at the same time then following the prompts).
The keyfob now works, and I didn't have to pay some ******* dealer $50 for 15 seconds.
"If you know more than me about how to do my job please sit right down at the keyboard and handle the problem.
However if you can't do that, sit down, shut up, and get out of my way."
I wonder if my boss would get mad if I started explaining that to my clients.
dragon300zx is offline
post #2 of 11 (permalink) Old 09-26-2010, 09:14 AM
Moved to DIY. Thanks for the write up.
hopefully this will fix problems might have with this issue
post #3 of 11 (permalink) Old 09-26-2010, 05:22 PM
ive been having problems with my keyless entry for a while, replaced battery many times and it works usually for a couple times then craps out,
this didnt solve my problem unfortunately :(
austinjjarboe is offline
post #4 of 11 (permalink) Old 09-26-2010, 05:40 PM
arman14's Avatar
Send a message via MSN to arman14
I have to try this with a new remote I bought.
Thanks
arman14 is offline
post #5 of 11 (permalink) Old 09-26-2010, 05:52 PM
hailcesar75's Avatar
Thanks
let me know if it works, my fob sucks. gotta press the buttons down hard for them to work
hailcesar75 is offline
post #6 of 11 (permalink) Old 09-26-2010, 08:13 PM
arman14's Avatar
Same here, that's why I bought a new one.
I'll let you know.
arman14 is offline
post #7 of 11 (permalink) Old 09-27-2010, 04:35 AM Thread Starter
Ok what you guys are discribing is different than what this fix is for.
This fix is for when your keyfob is no longer synced to your car, like when the battery completely dies and you don't replace the battery for another month or so. Then once it has a new battery it won't work cause the car doesn't recognize it.
What you guys are discribing is the crappy gm keyfob that has bad buttons.
You need this fix. Faulty Button as discribed in Blazers post.
Disable Car Alarm Honking??
post #8 of 11 (permalink) Old 09-27-2010, 06:21 AM
Awesome DIY.
post #9 of 11 (permalink) Old 09-27-2010, 03:30 PM
mine doesnt work at all right now lol. quit on me last week. gotta say, never again buying a chevy car.
2006 Chevy Cobalt 2LT Coupe - Majestic Amethyst Metallic - Auto Trans
Factory- power windows, power locks, keyless entry, sunroof, chrome exhaust tip, leather steering wheel, leather shifter, white face gauges, fogs, and spoiler
Showoff Thread
Scribs is offline
post #10 of 11 (permalink) Old 09-27-2010, 06:38 PM Thread Starter
Have you replaced the Battery Yet?
Did you make sure the battery holder (metal peice) has good solder connections and isn't falling off the board?
These often have to be resoldered. Just ask gbalt.
