View Poll Results: What should be my next performance mod?
Port and Polish w/tune with the AEM unit 7 46.67%
Forged Rods for FI 2 13.33%
Front and rear Sway bars 4 26.67%
Install a strut bar 2 13.33%
Voters: 15. You may not vote on this poll
  #21 (permalink)
Old 01-07-2008, 05:37 PM
gibsonj4's Avatar
Moderator
So you think I should not do the P&P on the cylinder head and do the other mods?
  #22 (permalink)
Old 01-07-2008, 05:41 PM
mind4engineering
Guest
Posts: n/a
i would go with suspension mods and get used to handling your car better, so your more prepared for if/when you go FI
  #23 (permalink)
Old 01-07-2008, 05:44 PM
gibsonj4's Avatar
Moderator
Well, I have the tran mounts, upper motor mount, and springs which I'm swapping for eibach. I'm getting the strut bar def. So what would be your next mod?
  #24 (permalink)
Old 01-07-2008, 05:46 PM
mind4engineering
Guest
Posts: n/a
i voted for the sway bars
i really wouldnt plan for FI unless you know for sure you can do it sucessfully on the 2.2L, and have a real tune, shoot...16k on a cobalt + 5+k for turbo setup and supporting monds and you almost have a SS/SC or even a TC
  #25 (permalink)
Old 01-07-2008, 05:54 PM
gibsonj4's Avatar
Moderator
TC's are said to be around 25K and Idk about affording that. I plan on getting the GT tuner kit from garett and the aem unit for a tune. NJHK and I talked about the O2 clamping issue and it will work. I just wanna run low boost until I get all the parts for the internals. The GT kit only pushes 8 psi good for 198 hp and 21X lbs/tq (don't know the exact figyure) What I don't like is that it is internally wastegated. Now, SCT has stated they are definately coming out with a tune for the 2007s L61's. The AEM unit would allow me to bigger injectors and get a decent tune for fuel management. I looked at an SC today for 15K it was used but I don't wanna get a supercharged 4. I just didn't like when I drove one. It felt held back to me. they are visually very nice though.
  #26 (permalink)
Old 01-07-2008, 05:58 PM
mind4engineering
Guest
Posts: n/a
well best of luck to you.
  #27 (permalink)
Old 01-07-2008, 06:01 PM
gibsonj4's Avatar
Moderator
Thanks bro and thanks for the input! This is how this forum is supposed to work and I'm glad it does.
  #28 (permalink)
Old 01-07-2008, 09:06 PM
BlackBalt's Avatar
Moderator
Originally Posted by gibsonj4 View Post
Yeah it's cool blackbalt. Thanks for the info I never knew about the moisture thing. Maybe I will save up and make one purchase for the parts I need. It might be better in the long run anyways.
Well I work in a machine shop where we mill huge piece of steel, aluminum, copper, etc all day...I know a thing or two about machining and what will happen in different situations. The cylinder sleeves inserted into the L61's aluminum block will be some kind of iron based steel alloy which will corrode and pit the surface. Not a good thing if you just paid big bucks to get your engine prescision machined at a professional shop.
2005 Cobalt LS: K&N intake w/ GMPP Pre-filter, LE5 intake manifold, LSJ exh manifold, LSJ downpipe, GMPP sport exhaust, Eibach Pro-Kit springs, Kosei K-1 wheels, DC Sports strut bar, Corbeau bucket seats, tinted windows, short antenna, partial rear debadge, 2006-present GM fender badges, stainless steel suicide knob, PIAA bulbs
  #29 (permalink)
Old 01-07-2008, 09:09 PM
gibsonj4's Avatar
Moderator
Well, I def appreciate the advice cause I know jack shit about maching my dad was a tool and die setter for GM for 30 years he knows so much shit about cars it's not even funny.
  #30 (permalink)
Old 01-07-2008, 09:13 PM
cobaltkrazy's Avatar
if you are going fi, you will need to plan out first, make it the main focus.......my suggestion is to get some suspension and handling stuff first, then brakes, then go for your FI, you will be set then
nothing like going FI, and not being able to make a corner
How to post pics:
Search this Thread:
Advanced Search
