exactly. even at idle it's not that bad anymore. the few times they're really noticeable is when you start the car when it's very cold out, (goes away once it's warmed up). also, if you're going very slow in too high a gear. like if you slow down for a speed bump, keep it in 2nd, and give it gas after the bump. you'll feel the car shake for a second.
normal driving, don't really feel it at all.
Well I guess I'm goin' to buy me some mounts if it's that good
2007 Chevy Cobalt SS 2.4 Mods so far: 17" Konig Hotswaps, 20% tint, GMPP performance cat-back exhaust and air intake, projectors w/ 6000K HIDs, 2 10" MTX subs, Alpine PDX 600.1 amp, flip screen Panasonic headunit, KSport lowering kit, shorty antenna. Future mods: Full bodykit, big brake kit, C-F hood, strut bar, sway bar, eng. and trans. mounts |
Def a great buy highly suggest
Triple Black 2003 Mustang GT Convertible Current Mods: | Motive 4.10 Gears | Mesh Grille | Zenn Drop Springs | BBK Shorty Headers | BBK O/R H Pipe | Smoked Tails | Fuego Tuned Upcoming Mods: 75mm TB | Plenum | Patriot Stage II Heads | Stage II Cams | Flows ![]() Goal: 310 rwhp N/A...then Supercharged |
Thanks alot for all the input and the help guys, I really appreciate it
Definitally get the mounts ...there is a deifference and its really not that expensive of a mod. I plan on doing mine. For the smoother shifts alone
I just installed front and rear tranny mounts on tuesday and I may take them out. The vibrations are pretty bad. It makes the whole car sound lowder inside the cabbin. Also it shakes the car REALLY bad if you bog at all. THe vibrations are worst at 1bout 1000 - 1500 RPM. I have already noticed them loosening up a bit, so I'm going to keep them for a few more hundred miles. If they don't loosen up a little more I'm going to replace one back to stock.
On the plus side I have noticed I am putting more power down to the ground. And I have NO wheel hop. But then again I rairly got wheel hop before..
![]() "A wise man speaks because he has something to say, A fool speaks because he has to say something" March 2008 in yourcobalt.com calendar |
