haha yeah actually a lot of honda guys do it....but a lot shit breaks on hondas too. Just was throwin it out there.
Triple Black 2003 Mustang GT Convertible Current Mods: | Motive 4.10 Gears | Mesh Grille | Zenn Drop Springs | BBK Shorty Headers | BBK O/R H Pipe | Smoked Tails | Fuego Tuned Upcoming Mods: 75mm TB | Plenum | Patriot Stage II Heads | Stage II Cams | Flows ![]() Goal: 310 rwhp N/A...then Supercharged |
haha me too bro...that's what I didn't buy a honda
2006 LS coupe, manual, Victory Red Sportlines, FE5 struts, shocks, front swaybar, Progressive 22mm rear swaybar, Airlift load assist rear airbags, TWM ST shifter, smoothed TB, LSJ exhaust, debadged, demudflapped, Yokohama AVID Touring P195/60R15's. Soon to come 17x7 Motegi Tracklight 1.0. Best to date 15.402 at 90mph "No friend ever served me, and no enemy ever wronged me, whom I have not repaid in full." Lucius Cornelius Sulla |
holy crap dude i've heard of that book. I looked on ebay for a copy and couldn't find one!
gibsonj4 added 2 Minutes and 32 Seconds later... CC's are everything too. I think most people don't really know compression refers to the stroke of the piston. that's what I mean about people throwing around lowering compression but don't really know what it means.
Triple Black 2003 Mustang GT Convertible Current Mods: | Motive 4.10 Gears | Mesh Grille | Zenn Drop Springs | BBK Shorty Headers | BBK O/R H Pipe | Smoked Tails | Fuego Tuned Upcoming Mods: 75mm TB | Plenum | Patriot Stage II Heads | Stage II Cams | Flows ![]() Goal: 310 rwhp N/A...then Supercharged Last edited by gibsonj4; 01-16-2008 at 08:40 PM. Reason: Automerged Doublepost |
To make the CR as accurate as possible you need a few formulas, numbers, a calculator, and a lot of time. You’ll also need to know pi, pi= 3.1415927. Now you can begin to calculate cylinder volume. Because Ecotechs are metric engines this number will be in cubic centimeters.
~Cylinder Volume = pi/4 x BORE (squared) x STROKE Now with that number we can calculate a rough CR which is ~CR = Cylinder volume + Chamber Volume / Chamber volume Seems simple enough huh? The real trick is applying the cylinder volume formula to the compressed head gasket and deck height. Then adding or subtracting them from the Chamber Volume. These numbers may be small but in the grand scheme they make a hell of a difference To prevent any copyright junk the above info is from Auto Math by John Lawlor ,an HP Book, published by Berkley Publishing Group, a member of Penguin Putnam Inc.
haha I knew what Pi was at least so this is for determining how much to lower/raise stroke?
