  #1 (permalink)
Old 01-27-2008, 08:06 PM
nugz's Avatar
Ecotec 2.0 TurboCharged
ECOTEC 2.0L (LNF) Turbocharged
Specifications
Displacement: 1998cc
Assembly Site: Spring Hill, Tennessee
Configuration: Dual Overhead Camshaft (4 valves per cylinder)
Horsepower: 260 hp @ 5600 rpm
250 hp @ 5600 rpm (HHR SS auto)
Torque: 260 lb.-ft @ 2500-5250 rpm
222 lb.-ft. @ 2500-5250 rpm (HHR SS auto)
Applications: Pontiac Solstice GXP,
Saturn Sky Redline, Opel GT, Chevrolet HHR SS, Chevrolet Cobalt SS
Features: Direct-Injection
Source: Gminsidenews.com
  #2 (permalink)
Old 01-27-2008, 08:08 PM
kickasscobaltss's Avatar
And we have a winner!!
2007 Chevy Cobalt SS 2.4
Mods so far: 17" Konig Hotswaps, 20% tint, GMPP performance cat-back exhaust and air intake, projectors w/ 6000K HIDs, 2 10" MTX subs, Alpine PDX 600.1 amp, flip screen Panasonic headunit, KSport lowering kit, shorty antenna.
Future mods: Full bodykit, big brake kit, C-F hood, strut bar, sway bar, eng. and trans. mounts
  #3 (permalink)
Old 01-27-2008, 08:11 PM
cobalt-z's Avatar
Post Freak
wow shes a beauty
yeah i mod, it's called having style.......
  #4 (permalink)
Old 01-27-2008, 08:12 PM
cobaltkrazy's Avatar
Excellent nugz, thanks man
How to post pics:
  #5 (permalink)
Old 01-28-2008, 07:24 AM
WolfmanDave's Avatar
Newbie
Here's some tidbits I found about the turbocharger. And although it talks about a vacuum pump towards the bottom, I read somewhere that everything with the LNF will be transitioning to hydroboost.
Turbocharger Description and Operation
A turbocharger is a compressor that is used to increase the power output of an engine by increasing the mass of the oxygen and therefore the fuel entering the engine. This BorgWarner™ dual-scroll turbocharger is mounted on the exhaust manifold and the lightweight turbine is driven by the waste energy generated by the flow of the exhaust gases. The turbine is connected by a shaft to the compressor which is mounted in the induction system of the engine. The compressor vanes compress the intake air above atmospheric pressure, thereby greatly increasing the density of the air entering the engine. The turbocharger is capable of producing up to 20 psi or 1.40 bar, of power-enhancing boost.
The turbocharger incorporates a wastegate that is controlled by a pressure differential, that is determined by the engine control module (ECM) by means of a PWM solenoid, in order to regulate the pressure ratio of the compressor. A compressor bypass valve also controlled by the ECM by utilizing a remotely mounted solenoid is integrated into the unit to prevent compressor surging and damage from vibrations by opening during abrupt closed throttle conditions. When the valve is open during closed throttle deceleration conditions, the bypass valve allows the air to recirculate in the turbocharger and maintain compressor speed. Within a calibrated range during the closed throttle event, or upon a wide open throttle command the valve will then close to optimize turbo response.
The turbocharger is connected to the engine oiling system by a supply and drain tube and Mobil 1™ synthetic oil is installed at the factory. Synthetic oil is required for its friction-reducing capabilities and high-temperature performance. There is a cooling system circuit in the turbocharger that utilizes the engine coolant to further reduce operating temperatures.
Charge Air Cooler Description
The turbocharger is supported by an air-to-air charge air cooler (CAC) system, which uses fresh air drawn through a heat exchanger to reduce the temperature of the warmer compressed air forced through the intake system. Inlet air temperature can be reduced by up to 100°C (180°F), enhancing performance because cooler air is denser in oxygen and promotes optimal combustion. The CAC is connected to the turbocharger and to the throttle body by flexible ductwork that requires the use of special high torque fastening clamps. In order to prevent any type of air leak when servicing the ductwork, the tightening specifications and proper positioning of the clamps is critical, and must be strictly adhered to.
Benefits of Dual Cam Phasing
The camshafts of the Ecotec 2.0 liter turbocharged engine have camshaft position (CMP) sensors and CMP actuators that the ECM uses to accurately control the continuously variable intake and exhaust valve timing. This allows the combustion process to be optimized by the ECM to increase the response of the turbocharger, providing a more immediate feeling of power to the driver.
Benefits of Gasoline Direct Injection
In the Ecotec 2.0 liter turbocharged engine, the fuel is introduced directly into the combustion chamber during the intake stroke. As the piston approaches top-dead center, the mixture is ignited by the spark plug, thereby giving the name spark ignition direct injection (SIDI). SIDI allows the mixture to be leaner, with less fuel and more air at full power. SIDI also allows a slightly higher compression ratio, resulting in improved fuel consumption at part and full throttle.
The fact that the fuel is injected after the exhaust valve closes allows particularly high valve overlap values in certain engine operating ranges. This enhances the turbocharger response time. This would not be possible in a port fuel injection (PFI) engine due to the fact that unburned fuel would escape through the open exhaust valve.
Direct injection’s precise fuel delivery enables more complete combustion which reduces emissions particularly on cold starts.
Electronic Vacuum Pump
The purpose of the electronic vacuum pump is to keep the vacuum in the brake booster at an acceptable level under various operating conditions. The ECM monitors the input signal from the brake booster pressure sensor. When the vacuum in the brake booster is not in an acceptable range the ECM will command the relay ON that controls the vacuum pump.
De-badged the Cobalt and re-arranged the letters. Coincidence? I think not.
  #6 (permalink)
Old 01-28-2008, 06:21 PM
nugz's Avatar
Nice add to the thread....
I love the sig too man...lol
  #7 (permalink)
Old 02-10-2008, 10:17 PM
Admin's Avatar
Site Admin
Digg this thread!
  #8 (permalink)
Old 03-18-2008, 01:03 PM
Newbie
is gm gonna come out a turbo kit for 2.2?
  #9 (permalink)
Old 03-18-2008, 06:42 PM
IMADreamer's Avatar
no, they most certainly are not.
  #10 (permalink)
Old 03-18-2008, 07:52 PM
Snake890217's Avatar
ouch harsh lol i wish tho... eh who am i kidding I couldn't afford it anyway.
-SSC Springs - TTR Rear sway bar - ADR 17" Battle Exe rims wrapped in Toyo Proxes 4 - Little Intake work w/ K&N high flow & Airbox mod -
- 8" 200 Watt Bazooka Tube - Blaupunkt Head unit - Blaupunkt speakers - Lights/neon inside - Streetglow Optx underbody -
NJ Tuners CarDomain Cobalt Facebook album
"Let it be."
Search this Thread:
Advanced Search
