not worried about warranty since i don't have any warranty left. i plan on getting the weapon r 4-2-1 header which includes a test pipe to remove the cat. come summer time i am going to have the local guy at the muffler shop make me a custom dual outlet exhaust using my obx mufflers.
i have the L61 2.2 with the getrag f23 trans.
cncd11 added 20 Minutes and 8 Seconds later... well i plan on that header unless i turbo it first...
2005 black base model, 17" MB gloss black drifter wheels, obx slash cut muffler, custom stereo system. future mods include: k-sport pro coil overs, eibach anti roll kit, JBP urethane motor/trans/control arm mounts, JBP strut bar, garrett turbo kit, GMPP fabricated intake manifold, gm ls1 76 mm cable driven throttle body, msd ecotec sync distributor, lower compression pistons, GMPP ported head, eagle rods and crank.................... one rout of many i may go with the car. Last edited by cncd11; 03-24-2008 at 02:14 AM. Reason: Automerged Doublepost |
how many miles are on your balt
i hate you.. why are you even a mod. you should know this.. you are by far the worst mod ever.
any alteration from stock platform excluding gmpp items will null and void you warranty if the problem is caused by said alteration. |
actually i am not going to do anything right away. I will run the car for a few hundred miles and see how it runs w/ a AEM AFR gauge. then if it is running lean which it probably will i will get a few lb per hour injectors higher. and go from there. i did this on my sunfire that i unfortunatly put into a ditch and the thing ended up running like a raped ape.
2005 black base model, 17" MB gloss black drifter wheels, obx slash cut muffler, custom stereo system. future mods include: k-sport pro coil overs, eibach anti roll kit, JBP urethane motor/trans/control arm mounts, JBP strut bar, garrett turbo kit, GMPP fabricated intake manifold, gm ls1 76 mm cable driven throttle body, msd ecotec sync distributor, lower compression pistons, GMPP ported head, eagle rods and crank.................... one rout of many i may go with the car. |
go look at my post for the quick 02 sensor fix it will make it so you dont get a CEL worked for me any ways
TEAM BOOST![]() Cobalt SS/SC Rally Yellow Appearance mods: 20% tint, Painted headlight housing, tinted tails Performance mods: Fujita CAI, 2.5" Down pipe with high flow cat, Tenzo R X-Spec muffler, 60Ib injectors, 2.9 pulley, one step colder plugs, and Powerlabs Custom tune |
yea do it im interested to hear how it works out i think you will be abel to feel a nice throttle respnse improvement after removing it...and as far as the eimissions shit screw that! who the hell cares they cant even agree where global warming is coming from i mean besides the fact that this was the coldest wettest winter weve had in years and here in louisiana where i live it was a record low temp for this time of the year, i dont think it really matters! my motto is drill a hole in a polar bears skull if thats what it takes to get gas back down to .98$ again lol
mods: short shifter, AEM CAI, 2.4 IM swap, Pacesetter header, custom downpipe, 2.5" custom exhaust, meagan carbon fiber & titanium tip muffler, 17" BBS rims, aerospeed lowering springs w/ adjustable cambers, black halo projector lights, blue brake calipers, blue wire harness engine bay |
You guys want a free car removal? Here's how you do it take the cat off the car and get a chisel and hammer the catalyst out. Put on a respirator (seriously don't skip that part) and get to work. It's going to take a while but if you work at it you can remove all the catalyst and bolt up the cat for a totally stock look. Then just use hp tuner or something along those lines to turn the rear 02 off. Say hello to better fuel economy and 7-10 more horsepower.
