OEM Replacement Spark Plugs - ACDelco Part Number? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 12 (permalink) Old 02-27-2017, 07:42 AM Thread Starter
Hey everyone,
Going to replace spark plugs on the Cobyashi Maru.
Been reading up on threads, but a lot of them are older.
I checked on Amazon and found ACDelco plugs (part #41-103) but have found other threads here stating that ACDelco part #41-981 is the actual replacement.
The 981's are $17 bucks a pop on Amazon, and the 103's are ~$7 a piece.
Car is stock, but planning on CAI and catback in the next 6 months, if that makes a difference.
Seen a log of threads on plat vs. iridium vs. double plat, but a lot of the threads I am finding are much older (some almost ten years). Just curious if anything has changed since the info in the threads I am reading.
As always, thank you!
-Jerm
jerminat0r is offline
post #2 of 12 (permalink) Old 02-27-2017, 07:45 AM
What year and engine is your car? Would help...
post #3 of 12 (permalink) Old 02-27-2017, 05:47 PM
Thogan3's Avatar
IDK if this helps......
http://www.yourcobalt.com/forums/gar...ehicle_id=4169
2009 Cobalt 5 speed Coupe
35% tints
Imperial Blue Metallic
2001 Ford Ranger Edge 4x2
Fire engine red
Tonneau hard cover
2003 Hyundai Elantra GT
5 Speed
Metallic Silver
Thogan3 is offline
post #4 of 12 (permalink) Old 02-28-2017, 08:38 AM Thread Starter
Originally Posted by Thogan3 View Post
Yep!
That's me.
2007 LS 2.2 Stock.
Thanks!
Jerm
post #5 of 12 (permalink) Old 02-28-2017, 12:28 PM
ACDELCO 41-103 IRIDIUM SPARK PLUGS GM#12625058 is the right plug for your car. The other one will work but it's a platinum plug and will not last as long as the dual iridium. I have 100K miles on mine and still waiting for a misfire count to change them..
post #6 of 12 (permalink) Old 03-01-2017, 05:57 AM Thread Starter
Awesome, thank you Coby.
Will these spark plugs still continue to be the preferred part with the CAI and Catback in the future or will I need a "cooler" plug? I don't think the CAI will cause that much of a difference as far as the spark plugs are concerned, but I still want to ask the experienced ones.
Thanks!
post #7 of 12 (permalink) Old 03-01-2017, 06:10 AM
No change unless you change compression.
post #8 of 12 (permalink) Old 03-02-2017, 06:29 AM Thread Starter
Wunderbar!
I got the plugs ordered. Should be here today or tomorrow.
Also ordered some grease for them. I have never used grease when changing my spark plugs (I know, I know..)
That being the case, how much should one use per plug? Just put a small dollop on the end of the plug once it's installed and then secure the boot or..?
Thanks again!
post #9 of 12 (permalink) Old 03-02-2017, 07:29 AM
Parthros's Avatar
Just FYI, I've got a CAI that I'm trying to get rid of. There's a thread over in the Sales subforum.
Parthros is offline
post #10 of 12 (permalink) Old 03-02-2017, 06:16 PM
Wunderbar!
Thanks again!
Just a dab inside each boot. Also put a bit of anti-seize on plug threads
---------- Post added at 06:16 PM ---------- Previous post was at 05:48 PM ----------
Just a note, I read on ProDemand that anti-seize is NOT recommended on the 2.2L... but personally I would use it.
2007 LT 2.2L
Mad_Max is offline
