i made a custom air intake for 40 bucks really simple to
www.andysautosport.com |
^^^ do you have any problems with throwing a CEL with the little breather filter? Unless i have the hose attached to the breather i get one...
![]() -SSC Springs - TTR Rear sway bar - ADR 17" Battle Exe rims wrapped in Toyo Proxes 4 - Little Intake work w/ K&N high flow & Airbox mod - - 8" 200 Watt Bazooka Tube - Blaupunkt Head unit - Blaupunkt speakers - Lights/neon inside - Streetglow Optx underbody - ![]() NJ Tuners CarDomain Cobalt Facebook album "Let it be." |
Okay, I noticed a difference in the CAIs.
Shank has the hose (yellow) hooked up for the breather on the head. Knox has a little filter. Where do you get the filter? I like that better than the hose.
2007 LT 2.2 MODS: GMPP Air Intake * GMPP Extrude Honed Manifold * GMPP Cat-Back Performance Exhaust * Vibrant D/P MOBIL 1 Synthetic Oil * Jet Stage 2 Module * DC Sport Strut Bar * Color Matched Mirror Covers Future MODS: 2.4 Intake Manifold Conversion * Tinting * Shorty antenna |
-----Added 15 Oct 2008 at 04:58:08----- Quote:
it makes more since to do what i did with the crank case because the crank case not only shoots HOT air back into the intake but also shoots oil from time to time, and oil going into the throttle body just doesn't sound good to me so on every car i get i always do this. Last edited by knoxbox; 10-15-2008 at 01:58 AM. |
it makes more since to do what i did with the crank case because the crank case not only shoots HOT air back into the intake but also shoots oil from time to time, and oil going into the throttle body just doesn't sound good to me so on every car i get i always do this. |
I will check that out.
I like the look. I'm guessing it is washable/reusable.
