its just like anything else its preventative maintenance you are there inspecting the spark plugs anyway, for the $12 it costs to get new spark plugs you mind as well replace them. and if you read the service manuals they say to inspect and replace if necessary which you should check your spark plugs more often then 100k miles.
2005 black base model, 17" MB gloss black drifter wheels, obx slash cut muffler, custom stereo system.
future mods include: k-sport pro coil overs, eibach anti roll kit, JBP urethane motor/trans/control arm mounts, JBP strut bar, garrett turbo kit, GMPP fabricated intake manifold, gm ls1 76 mm cable driven throttle body, msd ecotec sync distributor, lower compression pistons, GMPP ported head, eagle rods and crank.................... one rout of many i may go with the car.
