  #1 (permalink)
Old 01-03-2008, 07:25 PM
cobaltkrazy's Avatar
motor mounts(pics soon)
Okay, well, we need this back, so i guess i will do it up, seeing as i have DONE mine already(broke way back when)
i will post pics in a few days, gotta bum the camera from my mom.....
the front motor mount is located at exactly where it should be, the front of the motor(under the airbox)
first things first, you will need:
Jack(for motor)
socket set
flat head screwdriver
air tools(if available, makes life alot easier, but not nessessary)
start off by unscrewing the intake from the airbox lid
remove the airbox lid, and then the air filter
once removed, you will then need to remove the bottom portion of the airbox, easily done by unscrewing the two nuts at the top of the box(closest to the strut bar)(keep in mind, i am currently writing this up without looking at my car, i believe it is only them holding it in)
pull out the bottom part of the airbox, you may need some force to do this
once out, you have a clear view of the motor mount, roll the jack under the car, and proceed to lift up the motor only enough to take the weight, then unbolt the three bolts securing the mount to the motor, and the two holding it to the car
install the new mount using the reverse operations, same goes for the air box.
if all goes as planned, this whole job should take about 15-20 minutes to do, simple, straight forward, and easy.
check out the joke thread on my other forum:
http://www.civicforums.com/forums/17...ery-going.html
How to post pics:
  #2 (permalink)
Old 01-03-2008, 11:53 PM
gibsonj4's Avatar
Moderator
Air box haha what airbox? cai ftw
  #3 (permalink)
Old 01-04-2008, 03:52 AM
nugz's Avatar
I don't think we had a motor mount DIY before....anyway...nice post.
Also I see the part where you say "i am currently writing this up without looking at my car" Don't forget to verify the info you posted and make changes to the post accordingly, if you can't change it then PM a mod and we will change it for you.
Search this Thread:
Advanced Search
