  #1 (permalink)
Old 04-29-2008, 09:25 PM
BlackBaltSS's Avatar
Got LED's installed
So i got my footwell LED's put in
The pics are pretty low quality i know, but they look pretty good in person, and they only cost 9 bucks apiece. I hardwired it to the fusebox and wired a toggle inside the little cubby where the trunk release is.
Hurray for DIY Walmart mods lol.
2007 Cobalt SS/NA
  #2 (permalink)
Old 04-29-2008, 10:02 PM
Admin's Avatar
Site Admin
Looks good.. I like that look
  #3 (permalink)
Old 04-30-2008, 09:56 AM
TenYearsBeOhBe's Avatar
Post Freak
Lookin good man...
"... but it's ok, we're going to QuakeCon!"
"Black Betty" 2007 Black LS Coupe.
Visual: Debadged, Painted front bow-tie(gloss black), Yourcobalt.com Sticker applied.
Audio: Stock head unit and speakers, 2 Rockford Fosgate P210S4's sealed enclosure powered by Rockford Fosgate P2002
Performance: Injen CAI Pow Coat Black. Front tires P195R15 Fuzions, rear still sport the stock conts.
  #4 (permalink)
Old 04-30-2008, 11:56 AM
Moderator
pics arent showing here on my comp at work...maybe i will see when i get home
  #5 (permalink)
Old 04-30-2008, 03:15 PM
Snake890217's Avatar
looks good but where did you find a flat spot under the driver's side?? I had to mount mine behind the pedals at a weird angle
-SSC Springs - TTR Rear sway bar - ADR 17" Battle Exe rims wrapped in Toyo Proxes 4 - Little Intake work w/ K&N high flow & Airbox mod -
- 8" 200 Watt Bazooka Tube - Blaupunkt Head unit - Blaupunkt speakers - Lights/neon inside - Streetglow Optx underbody -
NJ Tuners CarDomain Cobalt Facebook album
"Let it be."
  #6 (permalink)
Old 04-30-2008, 03:32 PM
I didnt. I zip tied it to pre-existing wires that were mostly straight.
2007 Cobalt SS/NA
  #7 (permalink)
Old 04-30-2008, 03:52 PM
Ah got ya
"Let it be."
  #8 (permalink)
Old 05-01-2008, 01:04 PM
@tticus's Avatar
Newbie
any way you could post a diy for hooking it into the fuse box? im a retard when it comes to wiring stuff...
  #9 (permalink)
Old 05-01-2008, 09:15 PM
I guess i could try a shorthand version.
You want to be able to control the flow of electricity to anything from your fusebox because otherwise it will just be constantly running and drain your battery. That's why the toggle switch was neccessary.
1) Splice the ground and positive wires from both LED's together.
2) Run the ground wire to a metal grounding area near the fusebox (i used on of the strut bolts)
3) Run the longer positive wire through both sides of the toggle
4) Install toggle somewhere
5) Strip bare the end of the positive wire and remove desired fuse
6) Place bare wire underneath fuse and re-plug fuse.
Ta-dah!
Its a little more detailed than that, but thats the basic outline of what i did. Hope that helped at all.
2007 Cobalt SS/NA
Search this Thread:
Advanced Search
