Powerslot Front Cryo Slotted Rotors
![]() Description: Venting the gas from super heated brake pads improves overall brake performance. Of the various venting methods, slotting has the clear advantage. Slotting, unlike drilling, is not prone to cracking. Plus drilling delivers considerably less active braking surface - 8% less than Power Slot Rotors. The tapered slot also channels brake dust and heat away from the rotor and pad for improved braking ability. Power Slot Rotors are CNC-machined and come with an anti-corrosion plating that looks great behind custom wheels. When you need something tougher than a Power Slot rotor, but you're not quite ready for a big brake kit, try the new Power Slot Cryo rotors. Power Slot has teamed up with Frozen Rotors to offer cryogenic treatment on Power Slot rotors. Deep cryogenic treatment is a one-time process that permanently improves the performance and service life of metals, including brake rotors. Using a proprietary computer-controlled process, the metal is cooled gradually to -300°F and then slowly returned to room temperature and heat-cycled as the final step. Although not apparent to the naked eye, the improvements to the rotor are significant. The cryogenic treatment process redistributes residual stress in the rotor giving it an extra level of protection against warping. Allow 5-10 business days for processing. - CNC Machined! - Anti-Corrosion Plating And Cryogentic Treatment For A Longer-Life And Even More Protection Against Warping. - Slots Keep Rotor Cooler! - Slots Keep Rotor Cleaner! - Improved Wet Braking! Store Link: Never Enough Auto 877-609-6727 - Chevrolet :: Cobalt :: 05-Up Cobalt :: Performance & Power :: Brakes :: Brake Rotors :: Powerslot Front Cryo Slotted Rotors #8239C |
