Under Hood Fuse Box - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
Register Home Forums Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
YourCobalt.com is the premier Chevrolet Cobalt Forum on the internet. Registered Users do not see the above ads.
  #1
Old 09-03-2012, 02:10 PM
Exclamation Under Hood Fuse Box
Hey I have a question I thought i would check my fuse box today to see if all my fuses were good, because I have been getting a check engine light and noticed some of my fuses were missing is this normal? There are fuses in there for things I don't even have. Does anyone have any advice or maybe a diagram of the fuses that i should have in there for a base cobalt?
Old 09-03-2012, 02:17 PM
Bronxknight28's Avatar
Subforum Moderator
Subforum Moderator
All cobalts are going to have the same fuses, if you don't have the feature that the fuse says there's probably not a fuse there. The diagram is on the fuse box cover. If you have a CEL go to a auto store to get your codes checked and report back here and we can help!
Sent from my PG86100
MODS:Fe5 TC Shock + Struts\Moog Endlinks\YYZ V1 Springs\SC Gunmetal Wheels. GMPP Performance Exhaust\ZZP 2.5 Catted DP\K&N Drop-in filter\High Flow Intake Tube. Gen4 Headlights\6K Low Beam HID\LED 3rd Brake Light\LED Turn Signals,Plate,Trunk, Dome, Reverse, Side-marker\ Debadge "LT" & GM fender badges\Shorty Antenna
  #3
Old 09-03-2012, 03:17 PM
Thanks I actually just bought a code reader and should be receiving it in a few days!
---------- Post added at 06:17 PM ---------- Previous post was at 05:49 PM ----------
Man, now i have a serious problem checked my fuses and the car won't start now
  #4
Old 09-03-2012, 03:49 PM
Did you pull out any fuses to check them? Probably did not re-install in right slot. Don't panic .
Be generous, it feels so good to give!!!
  #5
Old 09-03-2012, 04:42 PM
Yeah i did pull some out to check them but my fuse box doesnt look quite like that, it turns over just doesn't start all the way
  #6
Old 09-03-2012, 04:59 PM
acoutu's Avatar
try disconnecting the battery, let it sit a few mins, reconnect, key in ignition in on position (dont try to start the car) let it sit like that for 10-15 mins. car off, wait a few seconds, try to start.
you might have tripped the immobilizer
  #7
Old 09-03-2012, 05:41 PM
do you have to have some sort of a security system for that?
  #8
Old 09-03-2012, 07:01 PM
Didn't think the fuse blocks were different between 2005 and 2007 aside from DRL fuse.
---------- Post added at 11:01 PM ---------- Previous post was at 10:59 PM ----------
My guess is that you moved the injector fuse to wrong spot.
  #9
Old 09-03-2012, 07:41 PM
My luck just keeps getting worse and worse now my battery died :/ i guess i will charge it tomorrow and see what happens
  #10
Old 09-03-2012, 07:49 PM
Charge it over night that way it will be ready for you in the morning.
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Content Relevant URLs by vBSEO 3.3.2
