P0013 P0014?? Is It Just the Exhaust Actuator?? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 4 (permalink) Old 02-27-2017, 06:16 PM Thread Starter
Just wondering if both codes are for the exhaust actuator. Or is it called the Camshaft Position Actuator Solenoid Valve? Thanks.
turtle is offline
post #2 of 4 (permalink) Old 02-28-2017, 10:31 PM
blu3_v1p3r's Avatar
Yes the camshaft position actuator. If you want OEM parts check out http://www.thatgmpartsguy.com
blu3_v1p3r is offline
post #3 of 4 (permalink) Old 03-03-2017, 08:19 AM
Jaws4God's Avatar
Send a message via Yahoo to Jaws4God
I get that code sometimes as well.. my father in law said my timing belt needed to be replaced... but i found out yesterday we have a chain.. so what would be a good thing to do?
Thank you!
Jaws4God is offline
post #4 of 4 (permalink) Old 03-03-2017, 08:39 AM
These engines with cam actuators are designed to run on synthetic oil. Synthetic oil doesn't sludge up like dyno oil. If you stretch your oil change intervals more than 3000 miles with dyno oil it will sludge and gather inside the actuators. Only solution then is to change the actuator. Simple one bolt one connector procedure. Remember the oil monitor is calibrated for synthetic so don't follow the oil monitor if you use conventional oils.
Coby7 is online now
