| Racing Solution www.RacingSolution.com |
Chevy Cobalt HID Headlight Conversion Kit
![]() Description: Increase your visibility at night with the new Xenon / HID conversion kit. This kit provides 3 times more light than conventional halogen bulbs. They use only 35 watts (40% less power than traditional 55 watt halogen bulbs). They last 10x longer due to their ability to withstand road vibrations better than traditional filament based halogen bulbs. This is a plug & play kit! Most people think all HID conversion kits are the same. Dont be fooled. This kit comes with a wiring harness that incorporates a relay and a fuse to ensure power comes directly from your battery and not through your electrical system. Cheaper kits on the market do not offer a built in relay and are powered directly from your factory haloben bulb wires. If you buy an HID conversion kit like this, you run the risk of an electrical fire in your wires due ot the high amount of voltage needed to ignite the bulbs when they first light up. Often times, youll need to replace your factory fuse with a 20 amp fuse. Our reliable kits offer safe long term operation because they connect directly to your battery and only provide power when the relay is activated. When the headlights are turned on, the relay is activated by the factory bulb plug which sends power to the ballasts Disclaimer: All HID conversion kits, no matter the source, are not DOT approved if installed outside of the factory. Moreover, in the U.S, this is not street legal for use on public roads. As a result, we officially endorse the kit for exhibition and off-road use and will only sell the kit to be used for these purposes. We are not responsible for buyers who violate the terms of sale. They will assume all responsibilities for any unauthorized or unintended use other than exhibition or off-road use. Store Link: RacingSolution.Com - Chevy Cobalt HID Headlight Conversion Kit |
