Loud Humming Noise - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 09-13-2011, 09:32 AM Thread Starter
Loud Humming Noise
2005 cobalt. loud humming noise coming from the front end. sounds like the driver side as well as feeling a little vibration in the floor on the driver side. Noise is speed controlled and not rpm controlled. (neutral down down a hill the noise still gets louder with speed) There is no vibration felt while driving and the noise doesn't get any bettor or worse with cornering or braking. Here's what I did. Swapped out the driver side wheel hub assembly and noticed that the cv axle was pretty wobbly on the transmission so I swapped that out as well. I also replaced pads and rotors and all that went well. Except now the noise is basically cut in half and I don't feel anything in the floor anymore. What are the odds that the wheel bearing is bad on the passenger side too? Furthermore, if that wheel bearing is bad as well I might as well assume the cv axle is bad too right? That would tell me something else must be wrong if both axle's and bearing are bad.
marcmiller2007 is offline
post #2 of 10 (permalink) Old 09-14-2011, 07:21 AM
Usually if one is bad, the other won't be far behind it.
My girlfriend's Cobalt makes this same noise. Very loud hum.
2007 Chevrolet Cobalt LT - M62 Supercharger, Ported Throttle Body, 42 lb/hr Injectors, Intense 2.9" Pulley, Cobra Heat Exchanger, SS/TC Exhaust, TTR Engine and Trans Mounts, Trifecta Tune, ZZP Header and Downpipe, '08+ FE5 Struts/Shocks, SSC Springs, FE5 Control Arms, SS/SC Front Swaybar, Powell Hardcore Rear Swaybar, 18" MSR 045s, Dunlop ZIIs, Nightshaded Tails/Side Markers, Shorty Antenna, Black Bowties, Black Grilles, Black Headlights, Dual JL 12" w1v2 Subs, A/D/S Front/Rear Speakers, G85 Recaros, Leather Rear Seats, 160 MPH Cluster.
1998 Chevrolet Cavalier - Cold Air Intake, Dual MTX 12" Thunder6000 Subs, Pioneer Speakers, Camaro Front Seats
2014 Chevrolet Cruze Diesel - 17" MSR 013s
1981 Chevrolet Camaro Z28 - JVC Ribbon Tweeters, SEAS Mids, Pyle Woofers, Kenwood Tape Deck, Zapco Amp/Equilizer
2017 Chevrolet Volt LT - New DD
MP81 is offline
post #3 of 10 (permalink) Old 12-03-2011, 04:22 AM
Exclamation same problem
i have the saem humming noise... driver side and can feel in in the floor. Last night i changed out the bearing on it and took it for a drive....no sound or anything til i hit 40mph... when i hit the the sound was back. before when it was bad i could hear it at any speed and it just got louder the faster i went.. but now only when i hit 40+ i hear it... could it be the CV drive shaft?? or something else??? i know its not the passenger side i replaced that 2 months ago when it seezed up( yeah did brakes and noticed something wasnt right. took it off and i couldnt turn it... took it to napa and they were like you drove on this??? the bearings are fused to the housing! may for a bad night) any one have any insite?? if it is the CV drive shaft how do i remove that??
whendrix13 is offline
post #4 of 10 (permalink) Old 12-03-2011, 08:20 AM
Wouldn't be an axle shaft if you hear a hum. Because there is only 6 or 7 bearings in the outer CV joint they produce a very low frequency and not a hum. Maybe a bad scallopy winter tire, have you tried exchanging front to rear to eliminate the tire? Drilled rotors when they rust also produce hum. How many miles on the Balt? Maybe you have a bad transmission or motor mount.
Coby7 is online now
post #5 of 10 (permalink) Old 12-03-2011, 10:08 AM
I've got 96000 on it.. its an 05.. 2.2L. No winter tires, and just had new tires in july put on and they get rotated a few weeks ago. And I had the problem then just wasn't as noticeable as now. Its on the driver side, I can feel it in the floor and hear it. Its like a rotating humm...like humm nothing humm, nothing and fast once you go faster... no drilled rotors either...just regular ones
post #6 of 10 (permalink) Old 12-03-2011, 10:43 AM
Then next I would check mounts, you might have a bad one and what you're feeling is transfered vibrations from engine and transmission.
Coby7 is online now
post #7 of 10 (permalink) Old 12-03-2011, 11:10 AM
how would i go about that???
post #8 of 10 (permalink) Old 12-03-2011, 11:23 AM
There are four mounts, one on the transmission,one below radiator, one in the front of the engine where all the pulleys are and one mounted on the firewall. Locate and visually inspect for any broken rubber or metal touching metal or if it just doesn't look centered. If they all seem OK do one last test, ''PULL PARKING BRAKE'' have a friend get in step on the brakes an engage in reverse and forward and check these mounts for excessive play. It will be obvious if one is bad engine will tip over and lean . You might even hear where it hits.
The ones that fail the most are the firewall and radiator ones because the other two are just pivot points.
Coby7 is online now
post #9 of 10 (permalink) Old 12-03-2011, 12:32 PM
okk ill check that and see what happens if those are good anything else i should look at while im under there that could be making the noise???
---------- Post added at 12:32 PM ---------- Previous post was at 12:00 PM ----------
on my way home tonight ill get a video / sound clip so you can hear it.. and you can all so determind it...
post #10 of 10 (permalink) Old 12-03-2011, 03:36 PM
Try swirving left to right when you hear this noise to see if it changes the hums pitch.
Coby7 is online now
loud humming , noise
