  #21 (permalink)
Old 01-14-2008, 07:46 PM
gibsonj4's Avatar
Moderator
You can always do some light ass rims but Ive heard horror stories of light rims snappping because they weren't forged. I've heard Traklites are good tho so if you wanna check those out here's a link: Motegi Racing Performance Wheels
Here are mine:Motegi Racing Performance Wheels
and correction my rims are 21.5lbs a piece
Stock rims/tires are 15 inches in diameter by 6.5 inches in width
  #22 (permalink)
Old 01-14-2008, 08:02 PM
Wheel Tech Guide - Tech - Sport Compact Car Magazine
checkout the how to decide section this isnt the exact article i was talking about earlier but it does say the smaller the better
2006 black cobalt ls
17'' MB drifter wheels, blacked out taillights, debadged, 1 12" kicker sub, 2 6'' 1/4 kicker front speakers, 2 1/4" custom exhaust, eibach pro-kit
  #23 (permalink)
Old 01-14-2008, 08:12 PM
gibsonj4's Avatar
Moderator
Hmmmm I like the section about different cast like forged vs. composite. Definite a must read before purchasing rims and tires.
  #24 (permalink)
Old 01-14-2008, 08:43 PM
cobalt-z's Avatar
Post Freak
i'm looking to purchase new rims and tires this spring for my cobalt ls 2007 i wanted to know if dunn tire would be a good place to get rims and if anyone knows of a cheaper place to get the set of tires and rims plus install??
yeah i mod, it's called having style.......
  #25 (permalink)
Old 01-14-2008, 08:45 PM
Red07SSNA's Avatar
Post Freak
I had good luck with tirerack.com for rims and tires.
07 Cobalt SS 2.4L Red Coupe
  #26 (permalink)
Old 01-15-2008, 07:26 AM
discounttiredirect.com is pretty good too
  #27 (permalink)
Old 01-23-2008, 10:54 PM
cobalt-z's Avatar
Post Freak
Exclamation sizes?
i want to get 17" rims and tires, but i want the widest
i can get that won't rub or anything like that when i turn and stuff. what size should i go with for tires? anyhelp much apreciated.
  #28 (permalink)
Old 01-24-2008, 10:44 AM
MattyFinch
Guest
Posts: n/a
Originally Posted by Red07SSNA View Post
The only way your 0-60 time would be affected would be if you get too large a tire on 17" rims. Check with the company that provides the wheels you want and ask them what size tire you need to keep the tire diameter the same -- or close to the same. If you end up with a "SLIGHTLY" smaller diameter tire overall maybe you'll pick up a 10th of a second. Also, the 17" wheels will probably be lighter then 15" steelies so that will help since you will have a little less weight to turn.
Remember going to a larger size wheel (rim) at the same time you get a tire with shorter sidewall the overall diameter will stay nearly the same.
you are an idiot
the weight of the tire+wheel combination is what can hurt his performance, and not NOT NOT the size of "tire".
the drivetrain has to spend more power to turn a heavier object, and YES the rim being bigger can in theory make it slow HOWEVER, light weight wheels can greatly reduce if no eliminate this issue.
MattyFinch added 1 Minutes and 30 Seconds later...
the widest rim you would EVER want to put on your car is a 7.5 inch rim, which is designed to run a 215 tire perfectly.
  #29 (permalink)
Old 01-24-2008, 11:35 AM
IMADreamer's Avatar
I just got mine from tirerack.com. They mounted and balanced them for free, the customer service guy I talked to was very nice, very knowlegable, and extremely helpful. A few hours after I ordered they called me to tell me that some of the hardware that came with my order would ship from a different warehouse eventhough it would still arrive on the same day they just wanted me to know that. IMO that's going far above and beyond the call of duty to please the customer. I will never order tires or rims from anywhere but tirerack.com after this experience.
  #30 (permalink)
Old 01-24-2008, 12:04 PM
You can fit atleast 225 thats what i run
Search this Thread:
Advanced Search
