Since you are a GM tech with a LS, maybe you can answer this. We both have stock 15s with 195/60/15. We could go larger like 16" like the 2LT models or 17, or 18.
I'll use OEM 16" with 205/55/16 as an example. I understand the +1 or +2 concept in wheel/tire size. But 205/55/16 is 1" taller compare to the 195/60/15. I understand the speedo and odo will be off. I get that. My question is, did GM actually made the "calcuations" on the two trim levels different? For my LT with 1LT package (15" wheels) is different from another LT with 2LT package (16" wheels)? The larger OEM wheel package is just taller than the stock 15" overall. It's not just +1 or +2.
2008 Cobalt Sedan LT automatic |
Yes you'll need to go to the dealer to have your car recalibrated(figure an hour labor charge, no parts) To work with the new size tire. The dealer will and can programm your car to the 205/55-16 tire size, and they may program it to the 17" Sport tire size(they dont have to, GM says not to, just a technical thing)
If you done have the recal done, your speedo/odo will be off and your ABS(if equipped) wont be functioning at its peak, because itll will "guessing" wrong when it first activates, and could potentially increase your stopping distance. <<<<A BIG SAFETY ISSUE They cant program to any other sizes. What I would recommend if youre okay with the 15" size is switching to a 205/60-15. It will make a noticeable difference and there are just as many higher performance tires available in this size as the stock size, also the difference in overall diameter isnt worth worrying about. Look at Kuhmo Ecsta ASX for a nice cheap tire(under $50 each), Goodyear GT-HR or BFG Traction T/A in the middle ground($60-70) and Michelin Pilot Exalto, Yokohama AVS ES100, and Bridgestone Potenaza RE92's in the high end(80-100)
ASE Certified master Technician ASE Certified Advanced Engine Performance Specialist GM Certified Technician GM Mark of Excellence Winner(Top Honors, Engine Repair) |
Good point. Yes, I have ABS. Never thought about that.
but yea any tires are better than the shitty contis but personally i wouldn't spend money on 205 its really not much wider...i went a lot wider...225/45
2006 black cobalt ls 17'' MB drifter wheels, blacked out taillights, debadged, 1 12" kicker sub, 2 6'' 1/4 kicker front speakers, 2 1/4" custom exhaust, eibach pro-kit |
