  #11 (permalink)
Old 04-20-2008, 08:40 PM
tigerpro357's Avatar
Send a message via AIM to tigerpro357
Easiest way to find out is try and put your stockies back on, if the shaking is gone, its the clips, if its still there, have everything checked, I had that problem on another car, turned out to be a bent axle (someone had taken my car offroad and didnt tell me that they hit a tree trunk) but anyway, The axle was barely bent, but it was enough to cause a problem.
Guy in Porsche: What you got in that thing?
Me: Its Bone Stock
Guy in Porsche: Wow, thats a quick car.
Me: Thanks
*Guy in Porsche Speeds Off*
http://www.cardomain.com/ride/2161243
  #12 (permalink)
Old 04-20-2008, 08:42 PM
Moderator
When i upgrade my rims i am definitally upgrading rotors, calipers and pads
  #13 (permalink)
Old 04-21-2008, 01:07 AM
cobaltkrazy's Avatar
Originally Posted by martz.w View Post
i heard somewhere to adjust the brakes that you can drive you car in reverse, stopping and going numerous times. I hear this automatically adjusts the brakes, which might help with the shaking when you hit the brakes. Just a thought
did you read the post by Nugz on the 4-wheel disc brake thread?
Originally Posted by nugz View Post
Also disks are better cause they have less moving parts and dont get out of adjustment as easy. Drum brakes require you to drive backwards and hit your brakes hard to adjust them. A large percentage of drivers are driving around with their drum brakes out of adjustment. disks are just plain and simple ......superior...That isnt just some guys opinion, Im a mechanic and deal with drum brakes all the time....they suck.
yeah, remove the clips, and you should be fine
How to post pics:
  #14 (permalink)
Old 04-21-2008, 08:41 AM
Moderator
I hate having drums in the rear and there a pain in the A$$ to work on
  #15 (permalink)
Old 04-21-2008, 08:55 AM
cobalt07ls's Avatar
Send a message via AIM to cobalt07ls
Adjust the drums and then it should be fine. I myself had just changed my wrapped rotors after only 15k miles on the car...and it's fine. Now with 21k the steering wheel is starting to shake and I'm going to adjust the back brakes here soon and inspect the rotors up front. I too have rims.
  #16 (permalink)
Old 05-10-2008, 01:04 AM
Newbie
Brake problems
You have put incompatible parts that are clearly not as good as the original parts. Put it back the way it was. Otherwise you will ruin your entire braking system.
  #17 (permalink)
Old 05-10-2008, 06:25 AM
Moderator
Mainly when the steering wheel shakes from braking it is from the front rotors, the drums shouldnt cause the shaking. If anything it will cause some pulsing
  #18 (permalink)
Old 05-12-2008, 02:10 PM
nanesnj's Avatar
Newbie
Send a message via AIM to nanesnj
Drums don't cause vibration. Rotors Do. Pulsations, vibrations, shaking or warping is couse by a different problems.
1. Variation In Manufacturing Tolerances
2. Sloppy resurfacing procedures
3. Buildup of rust and corrosion between rotors, hub and wheel.
4. UNEVEN TORQUE ON THE LUG NUTS
5. Loose Wheel bearing.
Try to get a new pair of rotors and pads, properly install them. IT doesnt have to be performace rotors though. If it corrects the problem they your set! Usually what couses this problem id the Disc Thickness Variation. If not then return them!
Now you say that the car is from 06. IT rotors should still be good. You'd be surprise how the ones breaking technic can damage the rotors and calipers.
S60 Componet Kickers front speakers, 6x9 4way XPLOD rear speakers, 2x12" XPLOD SUBS in a Kenwood Bandpass, 4ch Hifonics ZEUS Amp. 18" Wheels. SPECTRE CAI , Full set of INTERIORS NEONS. I HATE NJ THEY DONT ALLOW ANY GRADE OF TINTS ON THE FRONT WINDOWS!!!!
Search this Thread:
Advanced Search
