Try another tire pressure gauge....JK! Tire gauges are not the best "calibrated" tool you can buy. Have it checked out at the dealer, then you'll know if your digital gauges are any good. You'd be surprised at how many different readings you'll get from inexpensive tire pressure gauges!!!!!
07 Cobalt SS 2.4L Red Coupe CrateEngineDepot.com: GMPP: Int, Ext-Hone Mani Rand-Tech:2.75" Cat-back exh GM Parts: Red Dash/Shift Knob/Door Bezels, "SS" Hood Blnkt, Red Hood/trunk lid struts, Pedals, Hi-Prf Brk Rotors/Crmc pads, and '08 SS/TC grilles. Modern Performance: DC Sport Strut Bar and 2.4L VC Red Pwdr-Coated, Polished Oil Cap. IPCW: LED Tails AutoMeter: Oil Gauge in SS/SC pod pillar JEGS: Jet Chip Stg 1 Mod MRZ: UDP Pulley, seat braces GGBailey.com: 4-pc floor mats ProTint:Window tint |
I just took my car to the dealer to have the TPMS adjusted because after a tire rotation on a previous visit, the tech neglected to reprogram the tires. They adjusted the tire pressure to 32psi. The sticker on the door jam said the Pirelli's should be at 35psi. Slightly OT, but did you know that you can't put the spare tire in the front if you get a flat? I read this in the owner's manual. If you get a flat front tire, you need to take a tire from the rear, put it in the front then put the spare in the back. Something about bigger brakes or higher braking in the front two wheels. Just FYI. GTO, love your avatar.
'08 Coupe LT Sport Last edited by eggalegga; 10-09-2008 at 11:18 AM. |
Thanks for any info on this... GTO 1
2008 Cobalt Sport (SS), Imperial Blue... Lite-Glow Headlamp Bulbs / GM Sport Pedals. 50% 3M Tint All Around |
Low tire pressure
Well my tire pressure warning light came on last night. It was 32 degrees out when I drove home and the light came on. It was on again this morning when I got into my car to drive to work.
The DIC displayed tire pressures as low as 26 - 28 on my tires. I wonder if the tire pressure REALLY drops THAT low during winter months. If that's the case, I'll be having to inflate my tires daily. I still think the DIC isn't displaying the correct psi. I'm going to call my dealership and talk to someone in the service department. Just got off the phone with a service guy. He said he had no knowledge of an issue with Cobalts TPMS giving inaccurate readings. I suppose I will have to go once again and put air in my tires. If I fill them up to the Pirelli recommended 35 pounds, and the tire pressure warning comes on again soon, I'm going to press that the service department look into this further.
'08 Coupe LT Sport Last edited by eggalegga; 11-06-2008 at 11:45 AM. Reason: Update info |
as for the small spare tire,
you never put one on front of any front wheel drive car... different size tires will tear up the trans.......... digital pressure gauges are very accurate, unless you bought cheap stuff. |
