MPG Problem HELP - Page 3 - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #21 of 27 (permalink) Old 02-08-2014, 12:02 PM
I run 35ish winter, 38-40 summer
post #22 of 27 (permalink) Old 02-08-2014, 01:58 PM
Have you noticed any odd wear patterns on your tires or a bumpy ride?
post #23 of 27 (permalink) Old 02-08-2014, 03:57 PM
Higher than 35 which is standard on a touring/mild performance tire will improve MPG but wear out much faster. For 38 psi, your inner/center tread will wear faster. Just stick with 32-35 psi all year long. Your DIC should indicate when it drops below 28psi with a TPMS fault light on your dash.
If a fuel filter/strainer is clogged, then yes, it will affect your mpg, but with 45k mileage, should have no issues unless you have to buy cheapest fuel around town. I stick with Shell fuel, no preference, but better known than a mom-pops place. I would check spark plugs not for just replacing, but look to see what color they show, that will tell you a lot.
By the way, is your cobalt a flex fuel LT? and have you used e85 more than once? just wondering cause the factory injectors cannot withstand a constant change of fuel types. It will deteriorate the metal on the fuel injector solenoid, causing the injector to stay open all the time, reducing fuel economy, but a CEL should trigger as well.
post #24 of 27 (permalink) Old 02-08-2014, 04:18 PM
Nope, I know most tires wear out the middle like stealth said but my tires wore perfect, no scalloping or anything. They did wear out way to quick 20k km, but they're a cheap tire called geostar. As for ride comfort, other than hard turns I wouldn't have been able to tell they were pumped up higher than normal.
post #25 of 27 (permalink) Old 02-08-2014, 10:20 PM Thread Starter
Ok, is there a fuel filter on mine/ 09 cobalt LT? is it part of the fuel pump?
---------- Post added at 10:20 PM ---------- Previous post was at 09:35 PM ----------
And I had a DTC U2111...what does this mean? is there something wrong with that code poping up, no check engine light is on
Deven534 is offline
post #26 of 27 (permalink) Old 02-10-2014, 04:04 AM
That U2111 is loss of connection from PCM to another control module, possibly steering assist or near that area. A U code will not trigger a CEL, but it stands for loss of communication or networking to another module.
post #27 of 27 (permalink) Old 02-10-2014, 08:44 AM Thread Starter
So does that mean I should take my car in for that U code or shouldn't I worry about it?
Deven534 is offline
