Buzzing Sound in Speakers Rpm - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 07-29-2013, 11:14 AM Thread Starter
Exclamation Buzzing Sound in Speakers Rpm
i installed a new stereo in my balt a while back, and this buzzing noise that comes from the speakers drives me nuts. I have a pioneer avic touch screen with navi and all the interiors are powered through my four channel amp. There is a faint buzzing noise coming through the speakers that changes its pitch dependent on my rpms. I think it may be interference coming from the power cable into the amp interfering with the signal in the cables. Does anyone else have this problem and how did they fix it.
i made sure my ground is secure, it goes directly to the battery now. I did use cheaper rca cables when installing it could this be the problem? how could i reduce the interference when the wires need to run pretty much right next to eachother
loizzo is offline
post #2 of 6 (permalink) Old 07-29-2013, 11:25 AM
You are suppose to ground amp and whatever other device closest possible to body ground. By running ground cable to battery you create a ground loop.
post #3 of 6 (permalink) Old 07-29-2013, 11:54 AM
Jmesl8er's Avatar
Are your RCA wires away from your power and remote wires.
Jmesl8er is offline
post #4 of 6 (permalink) Old 07-29-2013, 01:28 PM
Also make sure input levels are not too low. You might need to balance amplifier output power with input level. In other words you might want to reduce the output gain and increase input level to minimize noise pickup and increase signal to noise ratio.
post #5 of 6 (permalink) Old 07-29-2013, 05:03 PM
i944scania's Avatar
Ground issues
07 LSJ turbo swap
-to4e 50 trim .63 a/r @ 19psi
-2.5" exhaust
-3" intake
-siemens #60s
-aem uego wideband afr
-HP custom tune
i944scania is offline
post #6 of 6 (permalink) Old 07-30-2013, 08:53 PM
Would wrapping up the cables together cancel out some interference? (Think wheel speed sensor)
