Problem with Head Unit Install - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 13 (permalink) Old 08-24-2013, 11:42 AM Thread Starter
Im installing a boss 612ua into a 05 base. Matched up all wires with the harness, and tapped the windshield wiper fuse for acc. All wires are soldered and fuses all look good. Firstly, I get nothing with ignition in acc position. Secondly, when ignition is turned to ON, I get a very faint lcd display on the head unit but no key illumination and no sound. Short of a bad head unit, could there be another problem? I havent even attempted to hook up amp, subs yet. Jusy testing it with basic function. Car runs fine and the unit I swapped it out for worked perfectly. Any thoughts? Thanks guys!
uspst00l is offline
post #2 of 13 (permalink) Old 08-24-2013, 12:25 PM
Jmesl8er's Avatar
Try tapping another source
Jmesl8er is offline
post #3 of 13 (permalink) Old 08-24-2013, 12:30 PM
stratosproject's Avatar
It seems that if it was an issue with your power wire, it would either work or not work. Can we assume this stereo is used?
---------- Post added at 02:30 PM ---------- Previous post was at 02:29 PM ----------
Also, how did you tap the fuse?
stratosproject is offline
post #4 of 13 (permalink) Old 08-24-2013, 01:34 PM Thread Starter
It was an ebay purchase. Listed as new. Looked new to me. The windshield wipers work fine so cant be a fuse problem. Tapped with standard fuse expander sold at advance auto parts.
---------- Post added at 12:34 PM ---------- Previous post was at 12:32 PM ----------
Also, what other source would be useable. Base model. So no sunroof.
uspst00l is offline
post #5 of 13 (permalink) Old 08-24-2013, 01:52 PM
Jmesl8er's Avatar
Take a wire straight to the battery, you'll know for sure if its the head unit that way.
Jmesl8er is offline
post #6 of 13 (permalink) Old 08-24-2013, 02:04 PM Thread Starter
So just take the red and black to the positive and negative of the battery?
uspst00l is offline
post #7 of 13 (permalink) Old 08-25-2013, 02:44 AM
Jmesl8er's Avatar
Jmesl8er is offline
post #8 of 13 (permalink) Old 08-25-2013, 08:30 AM Thread Starter
Ok tried that. Didnt get any response from deck. So im sending it back. New development is today I thought id throw the stock stereo back in until I get my replacement. So I install it and...nothing. does not turn on...now im like wtf?
uspst00l is offline
post #9 of 13 (permalink) Old 08-25-2013, 08:42 AM
I would go back and check your fuses. If you didn't disconnect your battery before wiring, something may have blown a fuse. Did you leave the stock harness intact? Hopefully you didn't do a hack job
post #10 of 13 (permalink) Old 08-25-2013, 08:58 AM Thread Starter
No hack job. I have a harness. Any fuse specifically?
uspst00l is offline
