2008 Cobalt Front Speakers and Chimes Go Off and on - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 6 (permalink) Old 12-04-2014, 04:35 PM Thread Starter
The front speakers work intermittently. When they work, they both work as do chimes. When not, neither works. There seems to be power to the plug in the door jams but not past the plug towards the speakers when they don't work. The dealer said need to replace both harnesses ($400 + labor) but doesn't make sense they would both go off and on if they were not somehow connected elsewhere. Any ideas? I've checked all connections I could and don't see any corrosion or fuse issues.
Thanks
gregverena is offline
post #2 of 6 (permalink) Old 12-05-2014, 05:46 AM
The chimes play through the speakers. Your speakers are probably just going out. Replace the speakers and you should be all set.
MP81 is offline
post #3 of 6 (permalink) Old 12-05-2014, 04:38 PM Thread Starter
Thanks for your input. I don't think the speakers are going since when they do come on, they both come on at the same time and are both very good. It's more an issue of power not making it to the speakers, but I can't figure out the exact signal flow from the radio to the speakers, At some point the 2 speakers must have a common connection, either ground or pos. which isn't making a good connection. Just can't figure out where.
post #4 of 6 (permalink) Old 12-05-2014, 06:44 PM
rains_crusader's Avatar
Do you have stock amplified system? Pull your radio and verify the dash harness isn't fraying and shorting against the dash structure. That's a common place for failure.
My front speakers used to cut in and out sometimes independently sometimes simultaneously. Speakers were bad.
rains_crusader is offline
post #5 of 6 (permalink) Old 12-06-2014, 05:19 AM
Yep - just like mine did (hence my post). Common problem, different symptoms for different cars.
MP81 is offline
post #6 of 6 (permalink) Old 12-06-2014, 06:54 AM Thread Starter
Thanks! Yes, stock amp. I did pull the radio and everything looked good there, but I might do it again to check more closely. Are there wires going from harness plug at radio that go directly to the speakers? I guess I should check those for voltage.
2008 cobalt , chimes , front speakers
