Wooow!!!!! - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 7 (permalink) Old 02-10-2010, 12:42 PM Thread Starter
SupaJenx's Avatar
Exclamation Wooow!!!!!
So I'm sitting in a parking lot, car running so I could have the heat on and I cycle through the info on my steering wheel and my coolant was at 208 degrees! It runs usually at like 190 cuz its bent wen I hit a curb. Should I look into replacing my radiator?
SupaJenx is offline
post #2 of 7 (permalink) Old 02-10-2010, 12:44 PM
mmmm rice<3
were u runnin it hard before you were stopped
tylerh is offline
post #3 of 7 (permalink) Old 02-10-2010, 12:44 PM
Thats normal if the car is just sitting idling. But if it is damaged...I would replace it.
post #4 of 7 (permalink) Old 02-10-2010, 12:58 PM
NitroheadZ28's Avatar
If you ran it, parked it and it was idling for a bit- then its normal for the temp to go higher as it idles.. But if you started it from cold, then then it should be at 170-180...
NitroheadZ28 is offline
post #5 of 7 (permalink) Old 02-10-2010, 01:15 PM
bchongarski's Avatar
mine do taht too - no worries
GM STAGE 1 :
bchongarski is offline
post #6 of 7 (permalink) Old 02-10-2010, 02:10 PM
208 deg F is not bad, especially if, while observing the temp, it went down afterward. Its when it hits 230 you have to look into maybe fan problems, sensors, etc. I just went through that with another old car I have.......
pippo is offline
post #7 of 7 (permalink) Old 02-11-2010, 09:05 AM
ItzBlueBish's Avatar
Low speed fan doesn't come on until 217* and shuts off at 190*. If you're at idle there's no air going through the radiator so it'll slowly creep to 217.
ItzBlueBish is offline
