Changing Suspension Right Now - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 15 (permalink) Old 07-11-2011, 12:42 PM Thread Starter
bbqdhamster's Avatar
Putting FE5 suspension on my balt right now - before I finish, anyone know the torque settings for the strut tower and maybe the control arms and other bolts i need to take off? I want to say it was like 60 lbs for the strut tower...
bbqdhamster is offline
post #2 of 15 (permalink) Old 07-11-2011, 12:47 PM
GpB311's Avatar
theres a thread with tons of torque info for various parts...let me see if I know where it is
---------- Post added at 12:47 PM ---------- Previous post was at 12:46 PM ----------
https://www.yourcobalt.com/forums/ins...apacities.html
GpB311 is offline
post #3 of 15 (permalink) Old 07-11-2011, 01:06 PM Thread Starter
Thanks a lot, I appreciate it! I'm kind of stuck though - the two bolts that bolt on the bottom of the strut tower - I can't seem to get them loose. I'm using an 18mm socket but it seems too small.... 19 is too big.
---------- Post added at 03:21 PM ---------- Previous post was at 03:18 PM ----------
This says to use 18mm, but it's on there really damn tight...
https://www.yourcobalt.com/forums/ins...g-install.html
---------- Post added at 03:36 PM ---------- Previous post was at 03:21 PM ----------
Ok I fixed that problem.
post #4 of 15 (permalink) Old 07-11-2011, 01:48 PM
GpB311's Avatar
If youre just changing the struts and therefore have to compress the springs and such, I recommend breaking the top bolt loose while its still on the car. I had such a hard time with it off the car and finally got an impact wrench and loosened it before taking off.
---------- Post added at 01:48 PM ---------- Previous post was at 01:47 PM ----------
many others managed to work with it off the car, I just wasnt so lucky I guess.
GpB311 is offline
post #5 of 15 (permalink) Old 07-11-2011, 02:03 PM Thread Starter
I'm changing the strut in the method i posted above. Having trouble with the torx bolt though.... I've done it before, just can't seem to do it this time.
post #6 of 15 (permalink) Old 07-11-2011, 03:13 PM
scagnetti76's Avatar
when i did mine, the large nut on top is what i took off first, while the car was still on the ground, then strut to knuckle bolts w/ jack under, then the three tower nuts...
scagnetti76 is offline
post #7 of 15 (permalink) Old 07-11-2011, 03:26 PM Thread Starter
All I need to take off is the torx bolt - the large nut on top. Car is up, but I don't see why that matters in this case. if it does, i can jack up the strut anyways. I got the passenger side off, just can't get passed the driver side...
---------- Post added at 05:56 PM ---------- Previous post was at 05:45 PM ----------
I've given that damn bolt everything I have for about 40 minutes now. It's not coming off.
post #8 of 15 (permalink) Old 07-11-2011, 03:27 PM
if your torx driver will fit inside the socket you can wrap the socket well with duct tape to cause friction, hold it with vise grips and turn the torx with an extension through the socket. did it on my ex's car and it worked like a charm.
post #9 of 15 (permalink) Old 07-11-2011, 03:35 PM Thread Starter
I have a torx driver but it's on like a pocket knife set up... no extension... idk if i can turn the strut. the duct tape goes outside the socket, and the vice grip holds the socket still?
post #10 of 15 (permalink) Old 07-11-2011, 03:39 PM
yes, but dont know if youll make it with that style torx. i assumed it was a socket type driver.
