what is the overheating temp? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 13 (permalink) Old 03-27-2015, 08:14 PM Thread Starter
This may sound like a dumb question to some of you.. But what temperature on cobalts is overheating ?
oscarmart1122 is offline
post #2 of 13 (permalink) Old 03-28-2015, 08:18 AM
xfe2008's Avatar
The fans will kick on low around 217-223, and then high at 230. I wouldn't worry at all until you start to exceed temperatures over 240+
---------- Post added at 08:18 AM ---------- Previous post was at 08:16 AM ----------
Coby will know more about it than I do though.
"Ask not what my monster truck can do for you, ask instead what you can do for my monster truck."
-JFK
And on this day the good Lord said, 'Let the big wheeled vehicle pass on into Heaven.'
Speed isn't everything. Sometimes, you just need a little style and flair in your monster trucking.
xfe2008 is offline
post #3 of 13 (permalink) Old 03-28-2015, 08:27 AM
rrob5382's Avatar
Boiling point for the antifreeze is 265F if that helps at all.. what Temps are you running that you are worrying about overheating anyways?
rrob5382 is offline
post #4 of 13 (permalink) Old 03-28-2015, 01:09 PM
Here are the specifications.
The ECM commands Low Speed Fans ON under the following conditions:
• Engine coolant temperature (ECT) exceeds approximately 106C (223F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off, the ECT at key-off is greater than 140C (284F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The ECM commands High Speed Fans ON under the following conditions:
• ECT reaches 110C (230F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set
post #5 of 13 (permalink) Old 03-28-2015, 02:22 PM
No dummy light on Cobalts?
post #6 of 13 (permalink) Old 03-28-2015, 03:55 PM
rrob5382's Avatar
It might pop a warning up in the dic but I don't think it has an actual light
rrob5382 is offline
post #7 of 13 (permalink) Old 03-28-2015, 04:24 PM
I've hit 239 with mine. I think I read somewhere that the light comes on at 240. It was over 100 degrees when I was keeping up with traffic and going around trucks at 80 MPH up hill on our way to Vegas from Phoenix. I was ignoring the "Turn A/C off" signs too.
kcg795 is offline
post #8 of 13 (permalink) Old 03-28-2015, 05:37 PM
I've hit high 230s at the road track. I'm concerned enough that I'm currently installing a front mount oil cooler. My main worry is the hotter the oil gets the less it lubricates as it becomes like water...
colodude18 is offline
post #9 of 13 (permalink) Old 03-28-2015, 05:46 PM
rrob5382's Avatar
but your car is also a little more than just a regular everyday driver haha
rrob5382 is offline
post #10 of 13 (permalink) Old 03-28-2015, 06:28 PM Thread Starter
I havent hit over 220 ... I just wanted to know cuz i wasnt really sure what the overheating temperature was on these cars... Its my first cobalt. I wanna be sure to take care of this car as much as possible. Its a good car. Just like alot of other people i kinda panicked once i saw hitting the 200's till i heard the fan come on at 217. But thanks for the input
