2006 Chevrolet Cobalt SS Supercharged 2.0L Ecotec - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 7 (permalink) Old 06-12-2010, 01:11 AM Thread Starter
Send a message via AIM to ThinkRusty87 Send a message via MSN to ThinkRusty87
Okay everyone i am finally getting around to ordering parts and am debating on what to do. My power goal is 300hp+. Right now i have just stage 2 installed. I was thinking about going a custom setup route but knowing me i will want more power and most likley change it around eventually.
So what i was thinking was get the supporting mods out of the way: Zzperformance 3" cold air intake, over the top performance long tube header, hahn racecraft 3" catless downpipe, hahn racecraft 3" cat-back exhaust, smoothflow pulley 2.7", over the top performance front mount heat exchanger, gm performance dual pass endplate, over the top performance option b, gm performance clutch, over the top performance rotated transmission mounts, hp tuners vcm suite professional tune, n2mb wot box (2-step and wide open throttle shifting), aem uego wideband air/fuel ratio gauge, siemens #60lb flowmatched injectors
I eventually want to port the stock m62 blower, port my head, build the motor, and spray the car as well. My other question is will i need anything else? What power level would i be at? what will i run in the quarter mile?
If anyone here thinks i should get one brand over another please put it out there explain why. I dont want to buy something now and have to replace it later on.
ThinkRusty87 is offline
post #2 of 7 (permalink) Old 06-12-2010, 08:00 AM
You will not see 300hp with those mods I can tell you that
Boostedecotec is offline
post #3 of 7 (permalink) Old 06-12-2010, 10:45 AM
sedan06's Avatar
x2
sedan06 is offline
post #4 of 7 (permalink) Old 06-12-2010, 12:10 PM Thread Starter
http://www.c obaltss.net/forums/showthread.php?t=217195
post #5 of 7 (permalink) Old 06-14-2010, 08:53 PM Thread Starter
I decide to do everything for supporting mods stated above, but go with the harrop tvs supercharger instead.
post #6 of 7 (permalink) Old 06-14-2010, 08:58 PM
WillBeck's Avatar
Great plan, but with the Longtube header a DP is a waste of money haha
WillBeck is offline
post #7 of 7 (permalink) Old 06-15-2010, 04:44 PM
Nighthawk243's Avatar
If you Convert to E85 w/ a TVS, you may be able to get close to 300 crank.
It would probably be a ton easier to just do a turbo swap. If you don't mind sitting at 250 for most of the time, you could do a GM stage 3 setup with a 76mm pulley and then have trifecta load its GM Stage 3 tune/OS onto your Stage II ECM (It will have Air Conditioning), and then just use the built in Nitrous provisions for a 50 shot. You'll have 250 (93 premium) or 260 (100 in High Octane Mode), and then have 300 for when you want it.
Nighthawk243 is offline
