How Do I Know if My Engine Has Been Upgraded? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 7 (permalink) Old 04-21-2013, 03:23 PM Thread Starter
I'm sorry if I'm posting in the wrong area.
Supposedly, my Cobalt has had a Stage 2 upgrade. How do I know if this is true?
It is a 2009 Cobalt SS manual (turbocharged, not supercharged).
Batman is offline
post #2 of 7 (permalink) Old 04-21-2013, 05:14 PM
That is BankerBalt's specialty.....But maybe this will help you and others understand how it works.
---------- Post added at 08:02 PM ---------- Previous post was at 07:59 PM ----------
Boost Control Description and Operation
A turbocharger (TC) is a compressor that is used to increase the power output of an engine by
increasing the mass of the oxygen and therefore the fuel entering the engine. This BorgWarner™
dual-scroll TC is mounted on the exhaust manifold and the lightweight turbine is driven by the
waste energy generated by the flow of the exhaust gases. The turbine is connected by a shaft to
the compressor which is mounted in the induction system of the engine. The compressor vanes
compress the intake air above atmospheric pressure, thereby greatly increasing the density of the
air entering the engine. The TC is capable of producing up to 20 psi, or 1.40 bar, of powerenhancing
boost.
The TC incorporates a wastegate that is controlled by a pressure differential, that is determined by
the engine control module (ECM) by means of a PWM solenoid, in order to regulate the pressure
ratio of the compressor. A charge air bypass valve is integrated within the unit, and is also
controlled by the ECM by utilizing a remotely mounted solenoid to prevent compressor surging and
damage from vibrations by opening during abrupt closed throttle conditions. When the bypass
valve is commanded open during closed throttle deceleration conditions, the bypass valve allows
the air to recirculate in the TC and maintain compressor speed. Within a calibrated range during
the closed throttle event, or upon a wide open throttle command the bypass valve will then close to
optimize turbo response.
---------- Post added at 08:05 PM ---------- Previous post was at 08:02 PM ----------
TC Wastegate Closed
The wastegate is completely closed at idle. All of the exhaust energy is passing through the
turbine. There are three reasons that the wastegate remains closed:
During normal operation, if a wide open throttle were to be requested at lower engine speeds, the
ECM will command the boost control solenoid with a duty cycle of 100 percent to minimize any
turbo lag. During engine loads in the middle and upper RPM ranges, the ECM will command the
boost control solenoid, with a duty cycle of 65-80 percent. Manifold pressures of up to 240 kPa are
possible.
TC Wastegate Open
When certain DTCs are set the ECM will limit the amount of available boost pressure. Limiting boost
pressure is accomplished by the ECM controlling the TC wastegate actuator solenoid valve and
maintaining the duty cycle at 0 percent. This means that the ECM will not actively close the
wastegate during greater engine loads. The system at this point is limited to mechanical boost.
Mechanical boost means that the wastegate will still move, but the amount of motion is limited by
the mechanical properties of the return spring within the diaphragm valve, the pneumatic
properties of the actuator, and the physics of the exhaust gas flow in the exhaust system. In this
mode of operation the manifold pressure will attain a maximum pressure of 140 kPa.
The TC wastegate diaphragm valve assembly has a threaded rod and nut that connects the
diaphragm of the valve to the wastegate. This rod is adjusted to BorgWarner™ factory
specifications and is not adjustable.
---------- Post added at 08:14 PM ---------- Previous post was at 08:05 PM ----------
Hope this helps!
post #3 of 7 (permalink) Old 04-21-2013, 05:26 PM
ssscgirl's Avatar
Send a message via Yahoo to ssscgirl
when i bought mine, mine was upgraded ,i just dk what they did i can only see some things they did.
2006 ss/sc G85 package K&n typhoon, Stage 2 Hurst sts
drilled and slotted rotors, painted calipers poly trans mounts 3'pulley.new megan exhaust new black headlights with hids
ssscgirl is offline
post #4 of 7 (permalink) Old 04-21-2013, 06:33 PM
This is what you got.
http://www.crateenginedepot.com/1921...17741C690.aspx
---------- Post added at 07:33 PM ---------- Previous post was at 06:52 PM ----------
http://www.gmpartshouse.com/19212670...bo-upgrade-kit
Cheaper!
Did they tell you if it came with the car or added after?
post #5 of 7 (permalink) Old 04-21-2013, 07:42 PM Thread Starter
19212670 Cobalt, Solstice, HHR Stage Kit 19212670
19212670 | LNF Turbo Upgrade Kit | GM Parts House
Cheaper!
They didn't say whether it came with the car or not. My immediate assumption is that it was added afterward.
Batman is offline
post #6 of 7 (permalink) Old 04-22-2013, 04:59 AM
Correct me if I'm wrong but I don't think gm made a gm stage 2. I've been out of the country so my bad getting to you late. If you have a staged gms1, you'll have a 3 bar map sensor and you will be boosting more than the stock 17psi. If you're higher than that, you're staged.
post #7 of 7 (permalink) Old 04-22-2013, 08:37 AM
Levee
Admin
Leveecius's Avatar
Not 100% correct. The GMS1 (which is the only stage kit for the 08+ SS/TC's), changed the MAP sensors to 3 BARs and completely re-tuned the car by the dealership. HOWEVER, the 17psi of boost as no reference to the stock boost on the SS/TC's. The LNF power plant's tune was all torque based. The tune was set to automatically raise/lower the boost (from the factory) to keep the exact same power all across the band. So if you were in the Rockies with really cold air, you could see 10psi of boost and still be putting out the same as someone in AZ in 120 degree air with 20psi, both completely stock. I've seen boost levels on a completely stock LNF (non-tuned) run 20psi, so boost has no relevence. To tell weather it's tuned is the top end pull, as well as how hard and when the boost hits, and how long it holds that boost at that level (basically not fading off). So that being said, really the only way to tell if it has the full GMS1 is the tune, which you would have to read it with HP Tuners or have the dealership look at it to tell you. You can buy the sensors for the GMS1 kit (which is what the links are), but anyone can put those in, that doesn't mean it's tuned for it. The car will still run with the 3 BAR MAPs, but won't run correctly in a tuners eyes.
If you're really wondering if it has the GMS1 on there, take it to a dealership and have them look at the tune.
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
