2.5" Vs 3" Exhaust - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 7 (permalink) Old 05-10-2013, 02:35 PM Thread Starter
2.5" Vs 3" Exhaust
HAs anyone seen dyno results on a 2.5" vs 3" catback on a SC cobalt I have heard the turbo is fine with a 3" but the SC needs more back pressure and a 3" is to much unless you are pushing over 300WHP. I have a Vibrant header and highflow cat that is going on it also.
beebrad is offline
post #2 of 7 (permalink) Old 05-10-2013, 02:53 PM
Jmesl8er's Avatar
According to 1320drag.net, Hahn, AMS and a one other I can't remember"
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side."While this applies better to a turbo car, i think it can be adopted for a S/C one............or a soon to be T/C or whippled car*
Jmesl8er is offline
post #3 of 7 (permalink) Old 05-10-2013, 03:05 PM Thread Starter
If I had the money I would swap the SC for a TC.
beebrad is offline
post #4 of 7 (permalink) Old 05-10-2013, 03:14 PM
Levee
Admin
Leveecius's Avatar
Exhaust size really depends on the type of power you want. The sc doesn't "need" back pressure. Back pressure (unlike a turbo) will give the same power because of higher boost leveos, and causes the engine (which on a sc 4 cyl car is bad enough as it is) to straij that much more. While strain on the engine is seemed bad, that strain is actually what helps you create torque. So a smaller exhaust will see higher tq and boost levels, where as larger exhaust will generally see lower boost and tq, but have better hp readings.
So, its up to you, do you want more tq or hp? That depends on the driving style and application and personal preference.
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
post #5 of 7 (permalink) Old 05-11-2013, 07:59 AM
It's all about flow.
Exhaust scavaging.
Velocity.
If the car flows enough to need 3" exhaust...then yes, you'd see gains.
Backpressure is a huge car world myth. You guys
Backpressure: The myth and why it's wrong.
I. Introduction
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Hondas need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
II. Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
III. Backpressure and velocity
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
IV. So how did this myth come to be?
I often wonder how the myth "Hondas need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
V. So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
VI. Conclusion.
SO it turns out that Hondas don't need backpressure, they need as high a flow velocity as possible with as little backpressure as possible.
From a Honda forum...still applies.
bluegtp91 is offline
post #6 of 7 (permalink) Old 05-13-2013, 04:37 PM
jonny_b's Avatar
I have heard this back pressure myth alot from my quad/dirt bike buddies since i was a kid. Mostly they say it because, "no back pressure burns out your valves." Which isn't true. Its just the air flows better, which needs more fuel. I am not a car expert, and the idea of more "back pressure" equalling more torque sounds believable, and i have read and seen dyno charts that say the same thing on the raptor forum i am on. Duner guys want wot power and have large diameter exhausts, and trail riders/woods racers go with a smaller diameter to keep more torque. But again i only know 1 cylinder, not 4 or more.
Sportlines and fe5-17x7 prime 142 wheels-225/45 achilles atr sports-slotted rotors-nightshaded tails with bowtie for legal purposes :( -shorty antenna-cavi short shifter-spectre intake piping with k&n drop in and the airbox mod+a little extra i thought up-thrush12"turbo muffler with 2-1/4" catback piping-pioneer avh1500 dvd headunit-pioneer 3 way 6.5 fronts-pioneer 3 way 6x9's rear-pioneer gtx5500 amp-12"kicker cvr (soon to be 2 pioneer 10's in custom boxes and another gtx5500.
jonny_b is offline
post #7 of 7 (permalink) Old 05-13-2013, 10:02 PM
You're right...but you're kinda right thinking back pressure is creating more "torque"...when it isn't. The torque effect is coming from the correctly balanced flow of each cylinder pulsating at the correct times to produce an optimal flow...where there is no restriction. So, I guess you could stuff a couple mufflers or cats on top of a super huge straight through exhaust and believe the backpressure myth...but in reality the car was just not in any need of that much flow to begin with...how's that?
