05 Cobalt 2.4l Intake Manifold Swap? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 36 (permalink) Old 05-29-2013, 07:36 PM Thread Starter
Hey everyone I've been reading a lot of these forum's on the 2.2l intake swap to the 2.4l intake Mani but here is my problem I have an 05 cobalt Lt 2.2l what year intake can I pull the 2.4l intake off of and have it be compatible? And where can I get one there is an 07 on eBay right now but I read in another forum that the 07 intake manifolds will require drilling a precise hole of the map sensor? Can anyone shed some light on the situation?
ace13733 is offline
post #2 of 36 (permalink) Old 05-29-2013, 07:39 PM
Any 2.4 on a l61 motor will work fine for you. Do a search of junk yards (might need to call) and ask for a 05-06 2.4L off either a cobalt or an HHR (thats how I found mine). Should be relatively easy, I always suggest people to call pams auto in MN, they have a wide search they can do from many junk yards.
And welcome!!
post #3 of 36 (permalink) Old 05-30-2013, 09:32 AM Thread Starter
OK now do u recommend getting the throttle body too?
ace13733 is offline
post #4 of 36 (permalink) Old 05-30-2013, 09:38 AM
Depends what you are looking for. I use both TB's depending on the courses I race. If you want to go fast and straight then yes you should get the 2.4 tb. If you want more torque and sacrafice some of the high end power then you can keep the stock TB and get an adapter.
post #5 of 36 (permalink) Old 06-04-2013, 12:24 PM
swanman35's Avatar
Thabks for the post, I had the same question. Do you known where I could get the adapter at?
swanman35 is offline
post #6 of 36 (permalink) Old 06-05-2013, 09:37 AM
i944scania's Avatar
keep in mind. from comparing dyno sheets, the curves change quite a bit. you do gain high rpm hp but consider what happens down low. is it worth it to be faster only when you beat on it more?
07 LSJ turbo swap
-to4e 50 trim .63 a/r @ 19psi
-2.5" exhaust
-3" intake
-siemens #60s
-aem uego wideband afr
-HP custom tune
i944scania is offline
post #7 of 36 (permalink) Old 06-05-2013, 09:53 AM
swanman35's Avatar
That's a good point
post #8 of 36 (permalink) Old 06-05-2013, 04:38 PM
i944scania's Avatar
i never did the bigger manifold mod but i looked at sheets people posted. looked like a loss of power low rpm compared to stock manifold.
07 LSJ turbo swap
-2.5" exhaust
-3" intake
-siemens #60s
-HP custom tune
post #9 of 36 (permalink) Old 06-06-2013, 09:23 AM
It's just a shift in the powerband...that's all.
bluegtp91 is offline
post #10 of 36 (permalink) Old 06-06-2013, 10:08 AM
i944scania's Avatar
right. could be good or bad. not worth the $400ish IMO
07 LSJ turbo swap
-2.5" exhaust
-3" intake
-siemens #60s
-HP custom tune
2.2l intake , 2.4l swap , manifold swap
