Timing Tentioner - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 5 (permalink) Old 06-03-2013, 06:01 PM Thread Starter
Timing Tentioner
for the timing chaing tentioner how would i know if the thing is set would i just smack the bolt on the head, whats the best ways you guys have got it to seat and how did u get it so the cams and chain didnt move?
derekhollister is offline
post #2 of 5 (permalink) Old 06-03-2013, 06:36 PM
Not sure I understand your question? Did you pull the tensionner out?
post #3 of 5 (permalink) Old 06-03-2013, 06:58 PM Thread Starter
no i plan on changing it because my car has the original one and has 97xxx miles
post #4 of 5 (permalink) Old 06-03-2013, 07:02 PM
The procedure is to take the valve cover off, tie-rap the timing chain to the pulleys then pull the old tensionner out. Insert new tensionner, torque to spec and you will have to reach in to press on the chain to depress the tip of the tensionner.
If you need to reset the tensionner just push and twist clockwise.
post #5 of 5 (permalink) Old 06-03-2013, 07:16 PM Thread Starter
i cant see the pictures on this computer (im at work) ill check when i get out and reply if im confused
