VVT Engines Explained - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 16 (permalink) Old 06-08-2013, 02:53 AM Thread Starter
This is for the members who don't have any idea of what Variable Valve Timing is in the 08-10 cobalts. Its more of today's emissions control than horsepower, since we don't use Secondary Air Injection/EGR Valve OBD-II systems.
He may not cover in this video, but VVT at cruising speeds will close the exhaust valve sooner so less NOx is produced for smog. This closes sooner than normal operation so less fuel will be needed for the next cycle of combustion, giving the exhaust more dilution and reducing the combustion heat (also reducing NOx).
I figured this will be a good visual aide for those who also want to look at upgrading/performance modification ideas and to understand what components to look at when modifying. This is valvetrain parts to pay close attention too. You cannot just slap an intake, header, and exhaust and expect horsepower/torque increase when your car is nothing more than an air pump. The PCM already has it set for amount of air going in and out, with them bolt ons, your PCM will go to what is known as "adaptive strategy" or last known good voltage. There is more to it than you normally know and coby7, bankerbalt, leevecius and a few other techy's know what I am talking about.
post #2 of 16 (permalink) Old 06-08-2013, 08:03 AM
09cobaltltsport's Avatar
So adding an bolt ons will give you the same performance basically?
Future mods:
chevy 572 c.i. motor insatall
09cobaltltsport is offline
post #3 of 16 (permalink) Old 06-08-2013, 08:23 AM Thread Starter
on some applications, it varies between engine design. I was told by a few techy's on here that the LAP motors that carry the VVT are already equipped with oversized valves to compensate for the bolt ons. Otherwise, if built by engineers to factory setup, your intake and header when during valve overlap, will just simply bypass during that phase and exit through the exhaust causing your cold air intake and header to just stream unburnt fuel and air, thus resulting in a rich fuel smell out the exhaust pipe.
adding a bit more of info:
Its very hard to explain, but shown is a good way of knowing. All engines are in compliance with 50 state legal emissions onboard. Therefore, you get a volumetric efficiency table (ive talked about this before), but that is the standard numbers they use to adapt to any environment, altitude, and air barometric pressure. When you get your tune, say for instance Vince from Trifecta, he establishes your VE table and re-calculates a generic table that is higher based upon your region of residence. This will allow for better air/fuel ratio and expand your valves for horsepower and torque. This is what is known as a tune. He takes what performance parts you have and re-learns a data table that is permanently stored in your PCM. So when you floor the gas pedal, his data table will kick in out of the 12 that are pre-established already in your PCM's learn mode or adaptive strategy. This is your common tune. A dynotune will enhance that power even more based upon where you reside and drive your vehicle. A dynotune will measure BARO for your MAP sensor, MAF sensor input, 02 bank 1 sensor, and other conditions in the local environment.
post #4 of 16 (permalink) Old 06-08-2013, 08:15 PM
cobaltune's Avatar
Nice right up for the newbies ,.........VVT for the win as always " F##k yo vtec".... GO CHEESE BURGER GO!!!
0-60....tooloonggg......Someone Wanna tune me =)
cobaltune is offline
post #5 of 16 (permalink) Old 06-08-2013, 09:25 PM
I think ill put one on just to upgrade the look of my engine compartment
Future mods:
post #6 of 16 (permalink) Old 06-25-2013, 08:41 PM
Then what is Ecotec? I remember reading it had something to do with exhaust valve timing for cleaner emissions, is this true? And does that count as VVT? I have an L61 engine with a CAI, and I've noticed a fair bump in mid to high end power, but a loss at low RPM, and it occasionally throws a P0171 code. Is that the PCM 'adaptively strategizing'? Would love to know.
post #7 of 16 (permalink) Old 06-26-2013, 05:59 AM
Levee
Admin
Leveecius's Avatar
Ecotec (capitalized ECOTEC, from 'Emissions Control Optimisation TEChnology') is a General Motors (GM) trademark that refers to a series of emissions technologies that were implemented throughout a range of GM engines.
That's what Ecotec is. Just a crap load more of emissions crap that I remove on every car I've owned lol.
P0171 System too Lean (Bank 1) - Read Our Article On Oxygen Sensor Codes For Help With This Generic Check Engine Light Code
That is your code, it's basically saying when you open her wide open your 02 sensor isn't adjusting your fuel quick enough. Not that big of a deal unless it STAYS on lol.
And you will lose a little low end torque when adding a CAI. Torque is built off restriction on 4 cylinder cars. If you have a tiny intake (lets say 1in in diameter for example), you will have LOADS of torque but not much high end power, but since you put on a bigger one, you lose that torque, but you gain good amounts on the top end of your spectrum. Make sense?
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
post #8 of 16 (permalink) Old 06-26-2013, 08:23 AM
Praise Ceaser! I always knew ECOTEC wasn't anything to brag about, I like to tell friends it's the anti-VTEC.
Regarding the code, then it's a simple case of upgrading the 02 sensors to something a little faster? I hear the term 'Wideband' thrown around here alot. I'm going to do a little research on the subject.
The torque thing makes sense. Then by the same logic, adding things like a header, downpipe, free-flow cat, cat-back etc will have a similar effect on low end engine torque? Thanks for sharing another glimpse of enlightenment, we really appreciate it.
post #9 of 16 (permalink) Old 06-26-2013, 09:32 AM
Levee
Admin
Leveecius's Avatar
No, a wideband sensor will not help you here, but they are nice to have. The WB sensor will give you an actual ratio readout on a gauge to help you while tuning, where as a narrowband will just say rich, lean, ok. Honestly, if you want to get that fixed, you need to re-tune your car to re-calibrate the MAF in your new intake to allow it to adjust the values correctly so that it will add fuel faster.
And yes, adding more bolt ons that will allow for better flow in your engine will do the same effect.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
post #10 of 16 (permalink) Old 06-26-2013, 03:10 PM
So the exhaust valve closes sooner, trapping some of the exhaust in the cylinder? And if this is the case, how does that use less fuel?
Crazed Cobalt is offline
