Coolant Reading _ _ _F FAN RUNS ON HIGH! - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 26 (permalink) Old 06-09-2013, 03:58 AM Thread Starter
kevin_911's Avatar
Exclamation Coolant Reading _ _ _F FAN RUNS ON HIGH!
My 2008 Cobalt 2.2 cooling fan is running on high speeds and won't shut off until I turn the car off. The coolant say it's _ _ _ F. Anyone have this problem before. If So can you help me out on How to fix it. By the way no Cell and yes the thermostat is open hot fluid in the hose.
2008 Chevy Cobalt LT 2.2!
kevin_911 is offline
post #2 of 26 (permalink) Old 06-09-2013, 04:30 AM
Bad connection to coolant temperature sensor or bad sensor.
post #3 of 26 (permalink) Old 06-09-2013, 04:37 AM
This. Its usually just a bad connection though
post #4 of 26 (permalink) Old 06-09-2013, 12:32 PM Thread Starter
kevin_911's Avatar
I checked the connection but no fix. So I'm going to try and replace it. Thanks for everyone's help.
post #5 of 26 (permalink) Old 06-09-2013, 12:50 PM
Delete the code and see if your temp comes back first. If it does, its a bad connection
post #6 of 26 (permalink) Old 06-09-2013, 12:58 PM
mine did the same thing and the connection was just bad the plug was dirty so it was locked together
derekhollister is offline
post #7 of 26 (permalink) Old 06-14-2013, 01:33 AM Thread Starter
kevin_911's Avatar
I replaced the sensor and it was working all day. Until I headed home from work and it's saying COOLANT ---F again. Connection is good,wires to plug is good. Is there a chance it could be the thermostat?
post #8 of 26 (permalink) Old 06-14-2013, 04:04 AM
Nope!
post #9 of 26 (permalink) Old 06-14-2013, 09:24 AM Thread Starter
kevin_911's Avatar
How would I go about fixing this?
post #10 of 26 (permalink) Old 06-14-2013, 10:37 AM
Follow the wires from the temp sensor to make sure it is not getting grounded somewhere it shouldn't be
