Building a Cobalt Ls - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 08-18-2013, 12:22 PM Thread Starter
Wickedgrimz's Avatar
i own a 2008 cobalt ls with cold air, mid range headers 1.50 primaries and down pipes to 2.50 exhaust. so whats next, is there a build up before turbo or just jump straight into turbo, what all can i do to build performance in torque before turbo.
Wickedgrimz is offline
post #2 of 8 (permalink) Old 08-18-2013, 12:39 PM
Gawd of Thunda!
SpeedyCobalt's Avatar
sleeves, new rods, new pistons?
MY SHOWOFF THREAD
SpeedyCobalt is offline
post #3 of 8 (permalink) Old 08-18-2013, 02:32 PM
He could get away with stock sleeves, rods and pistons are a must
post #4 of 8 (permalink) Old 08-19-2013, 09:04 PM
bfredrichs's Avatar
Banker is the guy to go to about engine stuff! He really knows his stuff!!
bfredrichs is offline
post #5 of 8 (permalink) Old 08-20-2013, 06:41 AM
Difference in LAP rods and pistons?
I know it's a GenII block...but the L61 is even weaker...yes?
bluegtp91 is offline
post #6 of 8 (permalink) Old 08-20-2013, 06:59 AM
No. Its all the same internals. Lap just has vvt and pistons with valve relief, same compression and strength though
post #7 of 8 (permalink) Old 08-21-2013, 09:45 AM
I'm in the process of gathering parts for a turbo build. I'm going to put everything on this year and for next build it. If you have a 2007 or later 2.2 it has the gen II block and you don't have to worry about sleeves. The rods and pistons though are just as weak and you'll need to buy at least rods pistons and head studs. It's around $1000 in parts.
post #8 of 8 (permalink) Old 08-21-2013, 12:02 PM
Its also smart to get new timing chains and tensioners.
Head gasket
Rod bearings
Valve cover gasket
Assembly lube
Clutch
Flywheel
Intake manifold gasket
Exhaust manifold gasket
Water pump
There are more things to replace than just the weak parts when you crack it open
cobalt ls performace
