Exhaust question? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 10 (permalink) Old 10-19-2013, 07:02 AM Thread Starter
Exhaust question?
So I got a small hole right behind one of the heat shields, I'm gonna take it to a local muffler shop and have them probably replace the whole exhaust pipe, what do you recommend I change? It's still gonna be on stock muffler. What would it sound like if I delete the cat? Go bigger pipe?
CamaroSS1969427 is offline
post #2 of 10 (permalink) Old 10-19-2013, 08:13 AM
Bigger piping doesn't always mean MORE POWER.
I'd just have them patch it.
If you're looking to upgrade, get a ZZP downpipe and an EBay catback like I did...then welded on a Borla ProXS muffler...sounds great for an N/A four banger.
bluegtp91 is offline
post #3 of 10 (permalink) Old 10-19-2013, 09:41 AM Thread Starter
Not wanting power, just a little better sound. Post a video of how your car sounds
post #4 of 10 (permalink) Old 10-19-2013, 09:52 AM
Option Racing 2.5" catback + the Borla muffler and a ZZP intake...otherwise stock.
926BEA31-421C-4E44-90AE-A8B7D386ED60-10330-00000810A0406080_zpsd247cb07.mp4 Video by bluegtp03 | Photobucket
FA0ADB3C-C537-4258-9452-AC2593B11A64-10244-0000080DEFC50AC0_zps12f012b1.mp4 Video by bluegtp03 | Photobucket
post #5 of 10 (permalink) Old 10-19-2013, 10:05 AM
An exhaust alone won't do much for power anyways, especially without a tune. It's illegal to run catless, and you'll actually lose power if the O2 codes aren't erased from the ECM/PCM. But if it's sound you want, go with what was stated above, best bang-for-the-buck I'm sure.
post #6 of 10 (permalink) Old 10-19-2013, 10:13 AM Thread Starter
post #7 of 10 (permalink) Old 10-20-2013, 06:03 AM
agreed sir. Catalytic Converters are not horsepower gobblers. The only reason to not have a cat converter is if your car is exempt from emissions (race setup only) and you pulled out the entire EVAP system.
For the 02 sensors, your car will be in limp home mode, in which a p0420 code will generate (catalyst efficiency). Your car defaults to open loop status, making your car dump more fuel and pull in more air. The only problem to this, is that your ECT (Engine Coolant temp sensor) will read a default below normal operating temperature, causing the engine efficiency not to be at its peak of performance and fuel efficiency.
This will also cause problems for your emissions, ever hear people say "that car is running rich" with a smell of fuel out the exhaust pipe? That is nothing more than excessive hydrocarbons (fuel) not being broken down in the cat converter or lack of a cat. This will eventually lead down to a mechanical misfire in the engine after time, your PCM relies on air/fuel control from the rear 02 sensor heavily on STFT and LTFT (short and long term fuel trim). Im not gonna explain that stuff cause there's a lot to it. So, if your car is running rich, your PCM is trying to increase more air to balance the ratio correctly, but no cat, no go. If you think a wideband would be a solution, dead wrong. Wideband is the front 02 before the cat (just a tip to remember in the future).
post #8 of 10 (permalink) Old 10-20-2013, 04:04 PM Thread Starter
I'll probably just put a new pipe on it to stock muffler
post #9 of 10 (permalink) Old 10-21-2013, 08:57 AM
Catback will be fine.
Won't mess with anything emissions wise...hence the CAT BACK.
post #10 of 10 (permalink) Old 10-21-2013, 09:53 AM
Batmobile's Avatar
If all you want is sound, get a muffler. And get the leak fixed obviously.
Before I got a full exhaust, I only had a "fart can" and it sounded pretty good for only costing me $30 to have it welded on.
Batmobile is offline
