Need Help with Electrical Issues/CEL Codes - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 32 (permalink) Old 10-25-2013, 03:10 PM Thread Starter
For about 3 months now, I've had the following DTC codes on my 2010 SS/TC (Mods are in my sig):
p0338 Crankshaft position sensor
p0031 O2 sensor
p0100 MAF sensor
p0458 Evap purge solenoid
First, I replaced all 4 sensors. No change.
I cleaned both MAP sensors and even replaced the O2 sensor at the down pipe.
The car tends to stumble a little at WOT, and seems to run rich (exhaust pops and sometimes backfires) but I still have full boost unlike with a p0101 code.
My RPD is showing "no data" on both the A/F ratio and cam phase angle screens. Starting to think I may need to replace my engine harness or maybe the PCM or ECM could be fried?
Really hoping someone can make some suggestions, I'm getting a little desperate here...!
colodude18 is offline
post #2 of 32 (permalink) Old 10-25-2013, 04:45 PM
Did you replace the fuse that supplies all these sensors. I believe it is called "EXH"
post #3 of 32 (permalink) Old 10-25-2013, 07:37 PM Thread Starter
Funny you should ask...I was planning to check all the fuses tomorrow in a last ditch effort to stumble upon something...
Thanks a million, I'll check that one first!
---------- Post added at 08:37 PM ---------- Previous post was at 08:05 PM ----------
BINGO!!!!!!
(Of course I couldn't wait until tomorrow)
Went out and checked it, and sure enough, it was busted! I replaced it, cleared the codes, started the car and held my breath....
Only one code returned, p0338 - crankshaft position sensor. That screen still shows "no data" on the RPD as well. I guess it may be worth replacing that sensor one more time. i know nothing's wrong because the car ran fine for 1,500 miles after the crankshaft was replaced and engine rebuilt back in July.
Coby, thank you SO MUCH!! If you lived closer and not in I'd drive over there and buy you a beer
You've made not only my day but my week AND month!!
PS: checked all the fuses while I was in there and my DRL fuse was busted as well, I assume that's the daytime running lights? Hadn't even noticed they were out lol
post #4 of 32 (permalink) Old 10-25-2013, 11:30 PM
Robsp32's Avatar
Typically when you have a range of sensor failure codes that are completely unrelated to one another, its usually a fuse.
Robsp32 is offline
post #5 of 32 (permalink) Old 10-26-2013, 05:36 AM
But these were all related to that fuse, that's why I pointed it out to him.
Hold on now, if car runs well, your "CPS" is good because otherwise it wouldn't even restart. Did you do a "CPS" relearn after install?
---------- Post added at 09:36 AM ---------- Previous post was at 09:33 AM ----------
If I drank beer and you didn't live so far I'd drive over and let you buy me a beer and a lap dance, lol
post #6 of 32 (permalink) Old 10-26-2013, 08:21 AM
Robsp32's Avatar
no no, what im saying is, sometimes you can have a MAF fail but trigger codes for another sensors, and vice versa on any other sensor and fixing the source of the problem may solve a range of codes. But having something like a CPS, MAF, o2, and evap code all trigger at once is usually the sign of a fuse. For instance I had a MAP sensor fail on my car, which also triggered o2 lean codes and cylinder balance codes. Ive had VVT solenoids fail which triggered cam timing codes and MAP codes because of low MAP pressure at idle. I think probably one of the most common misconceptions on a 2.4 is when the VVT solenoids trigger those cam timing codes people wind up replacing the cam position sensors and never fix the problem and wind up confused.
Robsp32 is offline
post #7 of 32 (permalink) Old 10-26-2013, 02:43 PM Thread Starter
I read conflicting stories about the car needing a relearn after replacing the CPS, so just in case I brought it into the dealership. They confirmed the LNF doesn't need a relearn. It's automatic.
Well in that case I'm glad you don't drink beer lol
I DID NOT offer any such thing as a lap dance - oh wait, you probably meant "Buy me a beer and [BUY ME] a lap dance"....
Hopefully
post #8 of 32 (permalink) Old 10-26-2013, 04:35 PM
Hopefully
lol, no lap dance from you unless you're a she thank you very much.
post #9 of 32 (permalink) Old 10-26-2013, 07:26 PM Thread Starter
Nope, I'm a 51-year old grumpy old man
post #10 of 32 (permalink) Old 10-27-2013, 09:52 AM Thread Starter
Spent a little time yesterday looking at my one remaining DTC code for the CPS. The connector off the engine harness has power so I'm suspecting the pigtail going from that connector to the CPS is the culprit. I've been trying to find a PN for it but to no avail. Does anyone know the PN?
Also, I think I'll have to take the starter off to reconnect a new cable. I replaced the sensor before during replacing the radiator so I had wide open access to it (which was really nice! (see pictures below).
From what I could tell the second bolt holding the starter motor in place is hard to get to. I want to pick up a set of ratcheting wrenches since I don't think I can get a socket in there. Anyone done this before? (my arthritis doesn't help either when it comes to tight spaces...)
