Turbo Status, Need Advice! - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 50 (permalink) Old 11-10-2013, 09:04 PM Thread Starter
i944scania's Avatar
Hey guys,
Havent been on in a while. thought id give you a little update!
So at the moment, heres what i have going on with the ss:
-to4e 50 trim with .63 hotside
-turbonetics deltagate with voodoo mbc set at about 19-20 psi
-custom 3" intake
-siemens #60s
-custom 2.5" intercooler piping with 4 ply couplers and t bolts
-zzp lsj intake mani adaptor plates for turbo
-2.5" catless lous exhaust
Heres a video when it only had a base tune:
Now has more timing and a safer tune thru HP. Video soon to come
The car is great up to about 6k.
When tuning, everything looked great, no knock and good maf calibration.
But for some reason, at about 6k(also when WG dumps) the rpms stop and we observe the MAF freq drop way down. I got my cat cut off the other day and it helped slightly, gave me about another 500 rpm but same problem.
Do you think this exhaust is too small for the turbo??
07 LSJ turbo swap
-to4e 50 trim .63 a/r @ 19psi
-2.5" exhaust
-3" intake
-siemens #60s
-aem uego wideband afr
-HP custom tune
i944scania is offline
post #2 of 50 (permalink) Old 11-10-2013, 09:13 PM
why does it take you so long for your wg to dump? leveecius would be the one to ask on this one
post #3 of 50 (permalink) Old 11-10-2013, 09:18 PM Thread Starter
i944scania's Avatar
well the its a .63 a/r turbine housing. I can get 20 psi at about 5500
07 LSJ turbo swap
-2.5" exhaust
-3" intake
-siemens #60s
-HP custom tune
post #4 of 50 (permalink) Old 11-10-2013, 09:21 PM
what are your IDC's at? and your AFR's? it could be an o2 sensor problem too
post #5 of 50 (permalink) Old 11-10-2013, 09:28 PM Thread Starter
i944scania's Avatar
i do have a small header/block leak. tiny on the turbo side. can hear it on start up, but when driving its gone or sneaks back under long idle. pretty quiet.
---------- Post added at 11:28 PM ---------- Previous post was at 11:26 PM ----------
it was pretty strange. So under WOT pull, afrs were good, i think he commanded 10.4 and they stayed around there. At the dump and 6k rpm, we watched the MAF Hz jump to almost idle numbers.
Seems like a coupler is collapsing on itself and blocking airflow.
07 LSJ turbo swap
-2.5" exhaust
-3" intake
-siemens #60s
-HP custom tune
post #6 of 50 (permalink) Old 11-10-2013, 09:28 PM
small leak can mean a lot on a turbo car. i'd fix that leak first
post #7 of 50 (permalink) Old 11-10-2013, 09:29 PM Thread Starter
i944scania's Avatar
and that was why i chopped the cat off. Figured it was clogged but it wasnt bad.
---------- Post added at 11:29 PM ---------- Previous post was at 11:29 PM ----------
i do need to fix it. its cold up here now and i need a warm day and a few hours to pull it apart again..
07 LSJ turbo swap
-2.5" exhaust
-3" intake
-siemens #60s
-HP custom tune
post #8 of 50 (permalink) Old 11-10-2013, 09:30 PM
HOLY RICH! do you have tbolt clamps on?
post #9 of 50 (permalink) Old 11-10-2013, 09:32 PM Thread Starter
i944scania's Avatar
yessir! lol thats only WOT and dependent on current psi. i have some data files from the HP software when we tuned
07 LSJ turbo swap
-2.5" exhaust
-3" intake
-siemens #60s
-HP custom tune
post #10 of 50 (permalink) Old 11-10-2013, 09:45 PM
are you misfiring? are you in open loop?
