Engine Swap? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 8 (permalink) Old 11-17-2013, 06:04 PM Thread Starter
Soaxin's Avatar
Engine Swap?
Id like to put an le5 in my base model or is it cheaper to build an l61?
Soaxin is offline
post #2 of 8 (permalink) Old 11-17-2013, 07:45 PM
Much cheaper to build the L61, it's not as simple of a swap as most would think considering it runs on a different ECM.
post #3 of 8 (permalink) Old 11-17-2013, 09:45 PM
Engine swaps just seem evil to me, but if you're going to do it, you might as well put a meatier motor in there. LNF/LDK perhaps?
post #4 of 8 (permalink) Old 11-17-2013, 10:56 PM
Just build the F61, it's not worth the headache of trying to swap an entire engine that runs on a different computer with a different wiring harness and getting everything to work.
post #5 of 8 (permalink) Old 11-17-2013, 10:59 PM
Honda guys do it all the time, it can't be that hard. If I had a dollar for every time someone mentioned B16s or K20s at mechanics school... jeez.
post #6 of 8 (permalink) Old 11-17-2013, 11:03 PM
Believe me when I say it's not as simple as the Honda engine for swapping them, there a lots of things different. How many engine swaps have you heard in the cobalt world, I'd imagine only a few if any, where as it's relatively common with Honda's. Theirs a reason it hasn't been done much, it's expensive, hard and quite frankly not worth it.
post #7 of 8 (permalink) Old 11-17-2013, 11:13 PM
As I stated, I don't care for swaps so I've never really bothered doing research on the subject. I just know that people with fast Hondas can be friggin' annoying sometimes.
I'd just think that anything can be done when enough money is thrown into it. But for a better $/hp ratio, it's better to just build your current motor I don't doubt.
post #8 of 8 (permalink) Old 11-17-2013, 11:20 PM
And that's what I'm trying to say, either build the L61 or start with a different engine in a different car to build, otherwise you'll spend so much more trying to do the swap even if it can be successful. I know you get attached to a car but the L61 when built is stronger than a non built engine, you also can run cams in the L61 which I dislike because they don't make any that work in the LAP.
