Motor swap - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
LinkBack Thread Tools
Old 01-06-2014, 06:39 PM Thread Starter
gypsy08's Avatar
Motor swap
is it possible to bolt my 08 l61 head on a 2012 2.4 l block?
gypsy08 is offline
Old 01-06-2014, 06:56 PM
Physically? Probably. Will it work? No.
Old 01-06-2014, 07:30 PM Thread Starter
gypsy08's Avatar
So can I get a 2.4 liter 2012 and put it in my 08 Lt
gypsy08 is offline
Old 01-06-2014, 07:36 PM
No
Old 01-07-2014, 05:26 AM
I know I'm taking a gen3 2.4l block with a 2.0l LNf head, lnf oil pan,LNf crank, zzp rods, 88mm wiseco pistons and building a 2.1l n putting it in my 09 LNf sedan
C_A_D88 is offline
Old 01-07-2014, 07:11 AM
Sounds ambitious. What kind of power/torque are you expecting to make with that setup?
Old 01-07-2014, 09:00 AM
Not sure yet but motor will b good up till around 700
C_A_D88 is offline
Old 01-07-2014, 09:01 AM
This guy right here knows his shit...I'd go by what he says
StevoElsupremo is offline
Old 01-07-2014, 09:22 AM
Wait wait wait...
2.4L block, destrokes to a 2.1 with ZZP rods and and an LNF crank?
I didn't know they were that different of rotating assemblies.
bluegtp91 is offline
Old 01-07-2014, 09:35 AM
2.4 block is honed to 88mm instead of 86mm. The stroke on the le5 crank is less to accomodate higher compression I believe. Putting higher stroke crank, lower compression pistons along with the head, its basically putting an lnf bottom end into a slightly larger casing. Makes perfect sense
