Turbo or Supercharger? - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 21 (permalink) Old 03-02-2014, 08:49 AM Thread Starter
ChevyCobaltLS's Avatar
Send a message via Skype™ to ChevyCobaltLS
for a 07 cobalt LS, what would you recommend?
First Car: 2007 Cobalt LS [SOLD]
Current Car: 2009 Cobalt SS Sedan
ChevyCobaltLS is offline
post #2 of 21 (permalink) Old 03-02-2014, 09:05 AM
Depends on what you want as an end result. They both have advantages and disadvantages. Turbo has more power potential overall, but it will be usable in the mid and high rpm ranges. They are a more complex system, so it won't be as "simple" to install. Supercharger has much better lower and mid rpm ranges, but will not do much in the high rpm ranges. It will also have a lower overall power potential from the start, unless appropriate mods and upgrades are done. With the right setups, either of these could be overcome in their limitations, but in basic form, those are what you'll get. Additionally, there are limits with the 2.2L L61 motor in it's stock form.
07CobaltGirl is offline
post #3 of 21 (permalink) Old 03-02-2014, 09:05 AM
Levee
Leveecius's Avatar
Depends on your goals. Turbo is what I always recommend because a properly sized and fitted turbo will always out perform a supercharger.
'09 SS/TC - Stolen
06 EVO IX MR/SE - Sold
'95 Ram 2500 Diesel
Speed Junkies Social Group
Leveecius is offline
post #4 of 21 (permalink) Old 03-02-2014, 09:05 AM
What's your goal? Turbochargers can make more power and get you to the redlight faster, but they are more expensive/complex. Superchargers are less expensive and simpler to run, but are limited in certain aspects like boost and efficiency. Basically, it takes power to make power, where as a turbo has no parasitic loss as it's the exhaust that runs it. One downside is that you may experience a delay, or lag, between the time you hammer it and when you feel power.
Many people here would prefer to go the turbo route, and I'm sure they'll tell you why.
post #5 of 21 (permalink) Old 03-02-2014, 09:11 AM
Levee
Leveecius's Avatar
Guys, a supercharger is far more complex than a turbo lol. And again, lag is determined by the size of the turbo. There is virtually no lag on the stock ss/tc turbo, but it also suffers top end because of that. Its all about turbo sizing.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
post #6 of 21 (permalink) Old 03-02-2014, 09:21 AM
When I say "simple" and "complex", the supercharger is just a blower, cooling lines, and a belt, for the most part. Sure there are lots of "little things" which also have to be added/changed, but the basic setup is simple. The turbo requires a lot more "little things" as it attaches to the exhaust, the piping for cooling, oil lines, plus other "little things" which must be added/changed. The basic setup is more complex because more things must be changed. Once you try to go into big setups for hp, the turbo is simple as the only thing which really needs to be changed is the turbo and tuning. The supercharger is only more complex when trying to compete with the turbo setup.
Not trying to start a debate on this. Just clarifying what I mean when I use these terms.
post #7 of 21 (permalink) Old 03-02-2014, 09:27 AM
The turbo ZZP supplies with their 2.2/2.4 kit is the Bullseye S252. I don't know much about that or how it differs from the stock K04. All I'm saying is that lag is a known side effect of turbo induction systems, whereas a supercharger is instant because it's running off the engine itself.
Generally, the larger the turbo, the longer the lag, the higher the top end, and vice versa for smaller turbos. A twin turbo setup (1 small and 1 big) should fix this problem I would imagine.
Lastly, complex or not, superchargers always seem to be cheaper. Maybe that's a reflection of it's performance capabilities versus a turbo? I don't know. I'm still green when it comes to FI and I'm learning this as I go. Correct me if I'm wrong on any of what I said.
post #8 of 21 (permalink) Old 03-02-2014, 09:34 AM
Levee
Leveecius's Avatar
Not debating at all, just stating from personal experience. It has always been easier to install a turbo than a sc to me and they both require work to make them work. Be mindful when I say NEITHER setup is just a slap on and go system. You will always wield better results with a turbo hands down. This is why more people go turbo than sc. Again, a properly sized turbo application will out perform a sc any day, in any condition.
---------- Post added at 11:34 AM ---------- Previous post was at 11:30 AM ----------
Turbo lag is a sacrifice of having big power. There are small ways to counter it slightly but not much.
As far as a TT setup, it depends on the setup (sequential or compound or bi setup).
The s252/6 turbos are much larger than the stock k04.
Youre learning quick tho
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
post #9 of 21 (permalink) Old 03-02-2014, 09:56 AM
Thanks. I'm still running NA so I don't really need to worry about any of this stuff. I only have to put up with being slow.
So since the OP would likely be buying or piecing together a ZZP kit, would that turbo cause any lag issues?
post #10 of 21 (permalink) Old 03-04-2014, 07:57 AM
Levee
Leveecius's Avatar
Well sure. That turbo is a medium frame turbo. It will lag a bit, but once it wakes up it pulls hard til redline. They are a decent turbo for the 2.2/2.4. I personally would never run one on my cars, but they are good for the price.
Ask bankerbalt about how that turbo works on the 2.2 as that is what he is running.
'09 SS/TC - Stolen
'95 Ram 2500 Diesel
