2.4 intake swap - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 17 (permalink) Old 06-10-2008, 06:49 PM Thread Starter
2.4 intake swap
ok this is probably a question some of you will laugh at but I would like an answer. If I the 2.2 to the 2.4 intake manifold swap, the next time I buy any new parts, should I buy them for the 2.4L engine?
youngdreamer is offline
post #2 of 17 (permalink) Old 06-10-2008, 07:00 PM
07CobaltLS's Avatar
All parts that you buy should be for the 2.2L.
The intake is the only thing I can see that you would ask this question for, but the intakes for the 2.2 and 2.4 are the same (at least I'm pretty sure they are...they may have different part number or something, but physically they should be the same).
You still have a 2.2L so just look for anything that works with that.
-Mike
|07' LS Sedan|Ultra Silver|Auto|MTX X Thunderlink|Debadged|35% Tint|Sportlines|Injen CAI|ARK Antenna|ARK STB| OTTP "Street" bar|Bridgestone Potenza RE960AS Pole Position 205-60-15|Hawk PC pads|PowerSlot Slotted rotors|
Not installed yet: Pacesetter Header|Exhaust Depot DP|LSJ Cat-Back|Injen Hydroshield|MSR 045 18x8 Black w/ Red Pinstripe
07CobaltLS is offline
post #3 of 17 (permalink) Old 06-10-2008, 07:11 PM Thread Starter
ok thanks. thats really what I wanted to know was for the intake and the exhaust. Thanks for the info.
post #4 of 17 (permalink) Old 06-10-2008, 07:16 PM
The intake runners are fairly different.
That's an honest question, but don't worry yourself over it. The only part I might worry about is the throttle body, but those are probably the same. Just stick with 2.2L parts.
BlackBaltSS is offline
post #5 of 17 (permalink) Old 06-10-2008, 07:16 PM
burzumaske20's Avatar
well when you do the swap,it wont effect you of having a 2.2 air intake system or anything like that.If you don't have a air intake or cold air intake,its kind of useless,both of those combined work well with each other including header,new downpipe,and a custom or catback exhaust,but also some other parts from a ss will work for a ls or lt model.I do have a list of what can work on a 2.2 from a list that a person has made.
Suspension:
FE 3,5 Shocks
FE 3,5 Struts
FE 3,5 Springs
FE 3,5 Front Sway bar
FE 3,5 Control Arms
Wheel hubs
Strut tower mounts
Rear axle
FE 5 Steering rack
Engine:
Exhaust Manifold
Downpipe
Exhaust
Intake Manifold (Will Physically fit but TB will not bolt up)
#32 Injectors Fit Leak free, Tuning is needed.
Pistons
Rods
Valve Springs
Supercharger and Throttle Body with Intake Manifold (tunning needed)
Drive Belt
Interior:
All of It
Exterior
Front Fascia
Rear Fascia
Rocker Panels
Deck Lid w or w/o Wing
Rims (07 only if you have factory alloys wheels.)
Headlights (SS are slightly tinted. I believe 07 has no orange reflector over DRL)
2006 Chevy Cobalt LT
Synthetic oil
K&N air intake system
Custom 2.5" dynomax exhaust system
B&M shiftplus
B&M tranny cooler
Catless Downpipe
stainless steel pacesetter header
5900k light bulbs
2.4 intake manifold
burzumaske20 is offline
post #6 of 17 (permalink) Old 06-11-2008, 12:11 AM
2.2 and 2.4 intake manifolds are not identical. The intake-to head gaskets are the same but the 2.4 manifold requires a PCV valve plate/gasket assembly whereas the 2.2 has a drilled PCV orifice and uses a separate gasket. The TB gaskets are different -- you would need the 2.4 TB gasket -- some 2.2 TBs will not seal properly so you should consider purchasing the CED intake kit as it includes a plate and gasket to insure a good seal. Finally, the brake booster vacuum line does not attach in the same place -- the 2.2 brake vacuum line attaches behind the intake while the 2.4 brake vacuum line attaches in front of the TB mount -- you would need the hose from a 2.4L engine (you could buy the correct size hose from a parts house but it won't be pre-shaped).
Also, make note that the 06 and 07 SS 2.4L intake manifold is a 1-piece cast intake while the 08 Sport 2.4L intake manifold is a 2-piece glued together intake just like the 2.2 manifold (but not the same part number). The 08 2.4L uses a different TB too.
Cobalt 2.4 Intake Kit
Ex-Cobalt Owner
Red07SSNA is offline
post #7 of 17 (permalink) Old 06-11-2008, 01:36 PM Thread Starter
thanks for the info guys. I was planning on getting the swap kit off of CED near the end of the month, but I wasn't sure where it was on my list of mods. But with the information that I've gotten from reasearch and stuff it seems to me like it will be my first along with CAI
post #8 of 17 (permalink) Old 06-11-2008, 03:51 PM
IMO the first mod should be the exhaust. The factory plumbing and muffler on a 2.2 is restrictive -- more for sound control than anything else. Opening this up will make the CAI and intake work better. When installing the CAI first it will make more noise then power because the engine still has to push the exhaust out the smaller exhaust. The GMPP touring cat-back exhaust is very good if you don't want a lot of noise and the GMPP performance cat-back is great if you don't mind the extra noise.
Ex-Cobalt Owner
post #9 of 17 (permalink) Old 06-11-2008, 04:19 PM
don't forget different headers and a new downpipe:P
Synthetic oil
B&M shiftplus
B&M tranny cooler
Catless Downpipe
5900k light bulbs
2.4 intake manifold
post #10 of 17 (permalink) Old 06-11-2008, 10:02 PM
IMADreamer's Avatar
Yep, far too many people over look these parts which are far more important as far as hp is concerned then cat backs.
Red is right though, the exhaust is extremely important and without major exhaust upgrades the 2.4 manifold won't get you the gains it should.
A 2.2 with CAI, 2.4 manifold, header, dp, and cat back should make for a very nice improvement over stock. IMO if you don't intend to go FI those mods I listed can't be beat.
IMADreamer is offline
