How-To: Installing Bi-Xenons W/ Relay Harness (Stock Headlights) - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 42 (permalink) Old 02-14-2010, 09:02 AM Thread Starter
Arrow How-To: Installing Bi-Xenons W/ Relay Harness (Stock Headlights)
How-To: Install HID Bi-Xenons Into Stock Headlights W/ Relay Harness
[IMG]http://*************/gallery/files/3/1/9/0/sl383250.jpg[/IMG]
9007 10,000k Bi-Xenon kit Bought From www.BuyHIDs.com - #1 Plug-N-Play Xenon HID Kits
Tools Required:
10mm Socket
Socket Wrench
3/4 Extension
REMOVE YOUR DAY TIME RUNNING LIGHT FUSE!! - Failure to do so may void warrenty!
Step 1: Remove the 4 top bolts that hold the headlights and bracket in place & the 3 Push clips on the grill.
[IMG]http://*************/gallery/files/3/1/9/0/sl383227.jpg[/IMG]
Step 2: Pull headlight out from the outside as shown. Takes some wiggling but it will come out
[IMG]http://*************/gallery/files/3/1/9/0/sl383228.jpg[/IMG]
Step 3: Remove the 2 lower bolts that hold the bracket in place.
[IMG]http://*************/gallery/files/3/1/9/0/sl383229.jpg[/IMG]
Step 4: Remove the headlight bracket by wiggling it out.
[IMG]http://*************/gallery/files/3/1/9/0/sl383230.jpg[/IMG]
Step 5: Mount your ballast under the headlight bracket as shown. Double sided tape works best. If your in the colder states heat the area up with a hair dryer before hand to help it stick. Mines been there for 1+ years without issue.
[IMG]http://*************/gallery/files/3/1/9/0/sl383231.jpg[/IMG]
Step 6: Here is a diagram of the Relay harness. It looks complex but its very simple.
[IMG]http://*************/gallery/files/3/1/9/0/sl383247.jpg[/IMG]
Step 7: Now take your relay Harness and wire the (+) Wire to the (+) post in the fuse box. The post just twist off. Install wire and tighten post back down.
[IMG]http://*************/gallery/files/3/1/9/0/sl383244.jpg[/IMG]
Step 8: Take the (-) wire and connect to to the bolt on the fendor. 10mm socket works.
[IMG]http://*************/gallery/files/3/1/9/0/sl383245.jpg[/IMG]
Step 9: Now run the wire for the passanger side (longest wire from relay harness) with the wires that run across the front beam of the car. Below is a picture and the red line is the "wire".
[IMG]http://*************/gallery/files/3/1/9/0/sl383249.jpg[/IMG]
Step 10: Now Take your Blue connector harness. Blue connector plugs into stock harness. The Male plug is not used on the passanger side, while the driver side it connects to the female connector on the relay harness. Refer to the relay harness diagram above to see what the connector looks like. The smallest wires connect together and the 2 plugs also connect together as shown below.
[IMG]http://*************/gallery/files/3/1/9/0/sl383248_766987.jpg[/IMG]
Now put everything back together, bolt it down and you now have Bi-Xenon HID kit installed into your ride.
*Thanks Dman090 for letting me use your pic without asking
Mkulrey13 is offline
post #2 of 42 (permalink) Old 02-14-2010, 09:29 AM
bbqdhamster's Avatar
Great write up, I will definitely be doing that this summer.
bbqdhamster is offline
post #3 of 42 (permalink) Old 02-14-2010, 09:35 AM
4dr-LS's Avatar
nice write up
lets say i put these on my projectors, will i be able to swap them into my stockers when i want
R.I.P. :(
Hello
4dr-LS is offline
post #4 of 42 (permalink) Old 02-14-2010, 09:38 AM
BlackARCA06's Avatar
Ok im still new to these HID's do I need a relay harness with Bi-Xenon.
2006 Cobalt: Bolt On's
BlackARCA06 is offline
post #5 of 42 (permalink) Old 02-14-2010, 09:45 AM Thread Starter
Yes, its a smart idea. Mine are included free with every Bi-Xenon purchase.
---------- Post added at 04:45 PM ---------- Previous post was at 04:44 PM ----------
nice write up
The HID kit yes, Bulbs you would need 9007. Your Gen 2's take H7 single beam bulbs.
post #6 of 42 (permalink) Old 02-14-2010, 09:49 AM
orangebalt13's Avatar
yeah and make sure their 9007 H/L, cause i made that mistake of getting the 9007 and not the H/L, good thing the sales guy emailed me before they shipped me it out so i was able to change it.
East Coast Cobalts: NY | Northern NY Cobalt Concepts
orangebalt13 is offline
post #7 of 42 (permalink) Old 02-14-2010, 09:55 AM
4dr-LS's Avatar
o alright
R.I.P. :(
Hello
4dr-LS is offline
post #8 of 42 (permalink) Old 02-14-2010, 09:56 AM Thread Starter
We only sell 9007 Hi/Lows (Same price as single beam) and 9007 Bi-Xenons. No Mixup here
post #9 of 42 (permalink) Old 02-14-2010, 10:17 AM
BoiseMCSS's Avatar
Mike, sorry but I need a quick refresher. What does the Bi mean? Does it mean Hi/Lo?
Also do you carry H1 bulbs and do you need a harness with H1 bulbs.
Thanks!
BoiseMCSS is offline
post #10 of 42 (permalink) Old 02-14-2010, 10:41 AM Thread Starter
Thanks!
Bi-Xenons = HID Low beam & HID High Beam.
High/Low = HID Low Beam & Halogen High Beam. The halogen isnt bright enough to use as a high beam but its there for inspection purposes
We carry H1 bulbs & complete H1 HID Kit. Relay Harness is not needed. PM me if you would like one or have any more questions
