2006 2.4l Installing OE Throttle Body - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
Forum FAQ's and How-to's (READ FIRST) This is a forum for all members to use when they have questions about anything on the forum.
 2Likes
  • 1 Post By KenyonKar
  • 1 Post By JL Taylor
post #1 of 6 (permalink) Old 11-04-2016, 06:17 PM Thread Starter
I am installing a new OE throttle body and it is acting like a vacuum leak 3,000 rpm idle, however no leaks. reinstalled old TB and idles normal.
to start with i had a P0121 loss of power. intermittent code. checked all wiring and no chaffing so i replace pedal switch and TB. now i cant get the TB to idle. the dealer has not mentioned any pigtail upgrades and the plug fits correctly.
any suggestions?
KenyonKar is offline
post #2 of 6 (permalink) Old 11-04-2016, 08:55 PM
It has a 3000 rpm idle with new TB? Bummer!
Seems your ECU needs to relearn / recalibrate to the new TB.
There is proceedure for that using a good GM programmer.
Check out
https://www.yourcobalt.com/forums/pro...ttle-body.html
And look at the following and follow instructions on page 6
http://www.gadgetmangroove.com/index...nts&Itemid=429
1966tbird is offline
post #3 of 6 (permalink) Old 11-06-2016, 07:48 AM Thread Starter
Thank you Sir!
1966tbird likes this.
post #4 of 6 (permalink) Old 11-27-2016, 06:42 AM
1966tbird......Excellent Post !
JL Taylor is offline
post #5 of 6 (permalink) Old 11-27-2016, 10:47 AM
Why thank you folks. You should also thank coby7
Just hit the like button and type in @Coby7
post #6 of 6 (permalink) Old 11-27-2016, 04:51 PM
You may also have a leak between throttle body and intake. This will also make RPMs high. Make sure gasket isn't cracked.
