Bumper Clips - Page 3 - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #21 of 39 (permalink) Old 10-27-2010, 09:48 PM Thread Starter
Originally Posted by dman090 View Post
all this talk of clips and brackets is confusing me lol. if you can get me a clear picture of the "bracket/clip" thru the fender, i can tell you what you need
uggggh i dont wana bring my car in the garage and rip it apart.
but if i have to i will. when i took my headlight and took the headlight bracket out i looked to the left. on the inner of the wheel well. there was one 10mm bolt. i unscrewed it and this piece that the bolt screwed into fell. its the same silver piece that holds the bottom of the headlight bracket together. than this long piece that is prolly 7 or8 inches detatched after i took the bolt off. that piece you can see in the picture. thats why my fender can be pulled back like that. i need another bracket and bolt to put on the top of that long bracket or w.e it is that fell to secure my fender
i hope this helps
---------- Post added at 12:48 AM ---------- Previous post was at 12:42 AM ----------
thats the long piece im talking to that is held in by the bolt and the bracket to the bumper on the inside of the wheel well.
i need another headlight bracket like thing and a bolt to secure it to the bumper as theres only one holding it to the car as on the driver side there is 2.
cobalt08ls is offline
post #22 of 39 (permalink) Old 10-27-2010, 09:49 PM
ok so the bolt to the left you looked at, does it bolt into the fender/ bumper?
dman090 is offline
post #23 of 39 (permalink) Old 10-27-2010, 09:55 PM Thread Starter
you slide that bracket piece on to the bracket i have pictured and you bolt it to the bumper im pretty sure. because thats how its held on now.
id have to take my driver side apart and see how many bolts are attatched to the long bracket.
---------- Post added at 12:55 AM ---------- Previous post was at 12:52 AM ----------
maby something slides back into place and i dont even need a bolt.? but looking at the driver side you can tell theres a bracket and a bolt right where i have the arow because you can see it when you look at the corner of the headlight. the other bracket and bolt is lower down at the end of the long bracket.
post #24 of 39 (permalink) Old 10-27-2010, 09:55 PM
so can you pull your bumper out freely like that? sounds like oyu need another bolt
dman090 is offline
post #25 of 39 (permalink) Old 10-27-2010, 09:58 PM Thread Starter
yes. on my passanger side i can just pull. on my driver side its tight.
which is the point of this thread and question in jepordy is all i need the 2 pieces pictured above.
number 3 and 4 the bolt and the bracket the bolt screws into.
and what exactly snaps into place as XFE stated
post #26 of 39 (permalink) Old 10-27-2010, 10:01 PM
the bumper snaps back into place
and #3 and 4 i believe is refering to the screw and the object the screw screws into on the head light bracket
dman090 is offline
post #27 of 39 (permalink) Old 10-27-2010, 10:04 PM Thread Starter
yeah but thats the same exact thing that holds that long bracket to the bumper.
it looks like on my driver side there is #3 and #4 on the top as i can see if i look thru the gap on the corner of my headlight.
so does the first square thing on the bumper snap into the piece arowed on the bracket? or is it held by the screw? on my driver side it looks like its held by the screw because i can see it
post #28 of 39 (permalink) Old 10-28-2010, 04:35 AM
hailcesar75's Avatar
Dude. You need 1 bolt and 1 clip. Take 1 of each from your headlight bracket and use that. Your not gonna lose or misalign the light beam
hailcesar75 is offline
post #29 of 39 (permalink) Old 10-28-2010, 07:24 AM Thread Starter
alright. than how do i snap whatever has to snap back into place??
post #30 of 39 (permalink) Old 10-28-2010, 11:51 AM Thread Starter
called chevy they want 40 cents for the bolt and 4.00 for the clip which the guy called a nut. im going to take my driver side apart and just double
check to make sure i need one of each amd not 2 of each.
can some one tell me a little bit more on how the bumper snaps on?
