My Retrofit Start to Finish - Chevy Cobalt Forum / Cobalt Reviews / Cobalt SS / Cobalt Parts
post #1 of 61 (permalink) Old 01-18-2014, 11:39 PM Thread Starter
SCR3AMz's Avatar
Mini H1 Retrofit kit Purchased:
Mini H1 Projectors
Morimoto 3Five *ballast
3Five 4300K HIDs
Mini Gatling Gun Shroud
Butyl Rubber Glue
MotoControl Bixenon: 9007/9004
194 drl leds
3157 switchback led turn signals
50W blinker resistors
CCFL inverters
White CCFL'S
Il update on progress.
My Retrofit kit
My projectors
My switch backs & ccfl inverters
Full headlights (Not disassemble)
One Headlight disassemble
Pair Full disassemble
Housings & bowls soaking in outdoor strength bleach & water
Removing most of the headlight Glue with heat gun & flat head screwdrivers.
Used headlight glue
Took projectors apart to get the metal plate that makes your hi/low beam
Painted the metal plate light blue
Heated up the metal plates in the oven to cure the paint
Blue metal plate with the solonoid back on
Projector put back together with painted solonoid plate
Used a multi tool to cut the rear rings behind the bowl for the projector to fit snug
Used the sander on the multi tool to get a good smooth back after cutting the ring off
Dremel the 3 points in the bowl ring to get a smooth ring
Test fit with half the projector
Taped off the middle part of the side reflectors
Primed the side reflectors
Painted side reflectors Satin Black
Side reflectors finished
SCR3AMz is offline
post #2 of 61 (permalink) Old 01-23-2014, 12:55 PM Thread Starter
SCR3AMz's Avatar
Well there's a start.
Update:
Sanded & Primed Housings, bowls & shrouds
Drilled holes in the back of the headlight plastic for the Ccfl connectors to go through
Drilled holes for the solonoid wires to go thought
First coat of blue on my gatling gun shrouds
Satin Black painted bowls
Satin Black painted Housings
Both drying for tomorrow we cure!
Soldered the 50w resistors & CCFL'S connectors onto the headlight harness
Both shrouds cured & on the mini h1 projectors
Put housings, bowls & reflectors in oven to cure the paint.
Ccfls silconed to the shrouds
Shrouds & projectors inside the bowls
Silconed ccfls wires & projectors wires so they don't move around in the bowls
Put together except the lenses
Rear of headlights with silconed holes
Whole thing put together and done
SCR3AMz is offline
post #3 of 61 (permalink) Old 01-24-2014, 04:32 AM
Nice start! Just don't eat the headlight for dinner on your table
post #4 of 61 (permalink) Old 01-24-2014, 11:18 AM Thread Starter
SCR3AMz's Avatar
I won't lol
SCR3AMz is offline
post #5 of 61 (permalink) Old 01-24-2014, 11:54 AM
Piece of advice SCR3AMz when you add pictures to this thread, edit them in the first post, that way you won't have pictures all over the place and it will be easier to follow for the rest of us.
post #6 of 61 (permalink) Old 01-24-2014, 12:03 PM Thread Starter
SCR3AMz's Avatar
SCR3AMz is offline
post #7 of 61 (permalink) Old 01-24-2014, 01:29 PM
What'd u soak it in to strip it?
C_A_D88 is offline
post #8 of 61 (permalink) Old 01-24-2014, 01:31 PM Thread Starter
SCR3AMz's Avatar
Originally Posted by C_A_D88 View Post
What'd u soak it n to strip it?
Outdoor strength bleach and water mix, I'm still waiting on one set to strip.
SCR3AMz is offline
post #9 of 61 (permalink) Old 01-24-2014, 03:00 PM
Originally Posted by SCR3AMz View Post
Okie
Also a small description with pictures is nice for newcomers. For instance that glue ball looks like something your cat coughed up to a newbie.
post #10 of 61 (permalink) Old 01-24-2014, 03:55 PM Thread Starter
SCR3AMz's Avatar
No cat lol
SCR3AMz is offline
